3 members (Lightholder's Dad, 2-Ton, TooMany2count), 83 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
#1545631 05/02/2024 4:58 PM
1958 ish 235 ,tearing this engine down to see if it is good to rebuild .It was stuck and has sat with oil for a few years in the garage but has not moved so I took the pan off and head and only found a bent push rod and stuck valve .I got the pistons out a few days ago and they look like origional gm pistons the rod bearings look okay as well as the crank so far .I tried to pull the harmonic balancer off and it won’t move .tried a few times using puller and impact ,then using puller and breaker bar ,I used a little heat with a heat gun to warm up the area ,no go .The puller even bent slightly.Any suggestions,
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
What kind of puller are you using?
Like this
"The Journey"
Follow in the DITY
As the line goes in the movie Jaws, you are going to need a bigger boat. You might need one with a little more substance.
https://www.summitracing.com/parts/pro-66514?
Mike
Thanks will have to upgrade
"The Journey"
Follow in the DITY
H Online: Content
Be sure you're pushing on the end of the crankshaft. Some pullers bottom out in the balancer bore, and they're fighting a lost cause. Find a deep socket that will slide through the center hole of the balancer, and push on it with the puller jackscrew. I've seen several pullers damaged and/or balancers destroyed by that problem. I've used the same "crowfoot" puller for over 30 years, and it hasn't failed me yet.
Like this one, but not as fancy:
www.ebay.com/itm/233822924622?
2X on the puller pilot hanging up on the ID of the damper.
BC
1960 C60 pasture art
