1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#1545182 04/27/2024 12:18 PM
What is the difference between these 2 push rods? Are they inter changeable? They are both the same length. Thanks, Grady. They are from a 216 motor.
1949 3100
Old Blue
GradyB #1545184 04/27/2024 12:57 PM
3B Offline
Hy GradyB, probably just a different manufacturer, if they are the same length I would use them in an engine rebuild/assembly, hope that helps
Ok thanks.
1949 3100
Old Blue
The one on the left looks like an aftermarket replacement part. Original pushrods usually had a more ball-shaped lower end.
The rocker arm's adjuster ball diameter is 11/32" (.344"), an unusual size, for all pushrods, and the pushrod cup must exactly match.
A smaller ball (5/16") will leave a wear ring part way down the cups inner surface.
GradyB #1545699 05/02/2024 10:43 PM
The one on the left was the rod that was slightly bent. I replaced it with the one on the right and adjusted to the specs found on here. It's a 38. It started and runs good. This engine makes more clatter sound than my 49 does but runs well. When I get a free day I'm going to run it and adjust after it is hot.
1949 3100
Old Blue
