7 members (hdgeren, NJC, Wickedbass, Gone, Otto Skorzeny, rfs56trk, Peggy M),
53
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 102 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 102 | I've never had this issue before... Had the truck for 5 years now. It's a 1952 Chevy 1/2 Ton with a 54 235 in it. Recently replaced the starter and had no issues for a while but now it just clicks once when I push the floor starter all the way down. I have to slowly let off with my foot and hold it ever so slightly off of full pressure and it will start engaging the starter. Does anybody have an idea as to what is going on? Im running 6 volts still. Just to recap... I have to push the floor starter all the way in and then gently let off but hold it at that position once it starts turning over. Is the bendix not engaging the flywheel properly? Could it simply be a bad cell in my battery even? It doesn't seem to be a problem with the button on top of the starter but it could be I guess. Any help would be greatly appreciated.
52 Chevy 3100
Jesus said to him, "I am the way, the truth, and the life. No one comes to the Father except through Me." -John 14:6
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | My guess would be the starter switch on the top of the starter. If the contacts are burnt at all, mashing it all the way down may not make good contact, but letting off may get better contact. I would inspect the contact on the switch itself and see what you find. You can get your battery load tested, but if the starter turns normally once you do your dance with the starter pedal, I wouldn't suspect the battery.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,690 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,690 | Get under the hood and move the stomp lever by hand and watch what happens.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Make certain the transmission in in neutral, wheels blocked. If it was 12v I'd advise to pull the coil wire.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jun 2023 Posts: 102 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 102 | So I pulled the starter switch and the contact in there is loose. It looks like some of the little stud behind the contact melted and now the contact floats a bit when pushing the button down. I am thinking I need a new switch. The one I have is only about a year old. I don't think it was making good contact. When I pushed it down by hand under the hood it would spark out from under it.
52 Chevy 3100
| | | | | Joined: May 2021 Posts: 42 'Bolter | | 'Bolter Joined: May 2021 Posts: 42 | Having the same problem with my new starter and switch. Hit the button and nothing happens. Could there be a thing about steel covered with what may look like copper? Took the starter off my truck tested on another battery and would not engage. Would another kick start switch solve my problem? Searching for answers.
1950 Chevy 3100 PU all stock
