1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
You all were very helpful with my last question on window trim. Let’s try a new question 🤣. I am rebuilding the bedsides on my 50 3100 step side. I am just going to buy sheet metal and replace the sides, $120 vs 5-600, but a lot of labor. My question is does anyone know what the angle is on the top rail to bedside for these beds?
Don't you have a protractor or a carpenter's speed square?
1950 Chevrolet 3100 (Ol' Roy)
I do but I cut the metal off already, was just wanting to try and determine what it was so I can get back close.
I'll measure mine tomorrow but someone probably will post the answer before then.
Thanks Otto
Angle between bedside and rail is 120 degrees.
That’s great, that’s close to what I am able to pull from it too even with the bedside metal removed. I didn’t cut loose the stale pockets on the cab sides, I should be able to weld on some new side metal pretty “straight” 🤣. Thanks for the help and angle check, this site always has someone to help. Off now clean some rust!
Yes, I measured mine and if the walls (vertical side panels) of the bed are at 0 degrees, the top angled portion is at 30ish degrees.
Craig
