0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 3,398 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,398 | I am not sure if this has been shared here before, but as I have been researching wheel bearings for some time it's worth sharing again. I was having problems trying to locate tapered roller bearings for the front of my "58 4400 "Thor". I had worn out my welcome at all the FLAPS in town, NAPA was trying hard but just couldn't find a match. Taking the measurements from the actual cones and races I buried myself in the internet, everything just brings another rabbit hole. I did finally come across a site that allows you to enter bearing measurements and search in that forum. This site gives you options for bearing type as well as dimensions. The end is a real Part Number that crosses to a Timken, National or SKF number. Using this I was able to locate bearings and get them ordered through Amazon at a greatly reduced price. Please take a moment and check out this link. https://bearingfinder.ntnamericas.com/
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 |
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | I will use this. Nice work and thank you for thinking of the rest of us!!
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
| | | | | Joined: Feb 2016 Posts: 148 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 148 |
-David
1953 2-Ton GMC
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Good source. Maybe the administration (Peg) can make it a sticky one n the appropriate forum
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Peggy isn't the *only* one around here, you know ... Seems to be a site applicable to all of Stoveboltdom, ja? Let's move it to Driveline if only wheel bearings. We could move it to General Truck if all types of bearings (wheel, tranny, engine, etc, etc., etc...). If we get enough positive feedback, we could consider possible follow-on options. Like making it a sticky ... making it a Tech Tip of sorts ... or something else. I *do* have an open mind about these sorts of things, you know ... So ... where to move it??
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2007 Posts: 3,398 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,398 | The site is for all types of bearings. Automotive and industrial would the most used by Bolters.
