1 members (3800GUY),
89
0
Mod | | | Forums66 Topics128,189 Posts1,057,336 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | Let's start here. 1. Front clip removal. 2. Engine removed, put on engine stand, crankshaft replaced. Run? Not under it's own power......but, after thinking about it, the pax floor board kinda looks like doing it the Flintstone way may be a possibility, but switching gears and steering may also be huge problem (but yes it does roll). ALSO, changing the crank will also entail modifying the block to accept the newer main bearings. Don't need a boring machine. Just need a real steady hand and (according to Jerry, "two brain cells to rub together and a dremel tool). I've got the tool but not the cells nor the steady hand. The notch has to be put into the block because that side of the bearing doesn't have the dowel. The cap side does but not the block side. Jerry, did I explain that right? But, 2 Ton, you already knew that so why am I explaining it to you; oh, wait! Like I told Jerry, I haven't got ANY brain cells to rub together. S2 PS So, yes, I hope Jerry CAN make it because that means his medical concern will be doing better. Wrenchfest '24 -- "Potomac Palooza" (MD) 26-28 April 2024
Stewart2 1955.1 3100 Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC Jack of several trades and experiences; Master of none
| | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | John, all I have to do is put the stand together. If we can "git 'er dun", and Jerry shows up, he'll be able to take the other engine with 'im. So that sounds FATASTICO to moi!!! Thanks!!!!
S2 Stewart2 1955.1 3100 Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC Jack of several trades and experiences; Master of none
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | John, all I have to do is put the stand together. If we can "git 'er dun", and Jerry shows up, he'll be able to take the other engine with 'im. So that sounds FATASTICO to moi!!! Thanks!!!!S2 If the block is stripped down to bare bones, it would be a good time to machine it for a full circle lip seal instead of a rope or 2 piece rubber seal at the rear main bearing. Like this: www.ebay.com/itm/154260983108I have several of them on hand at the moment Jerry
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Hrl is anyone actually running this one piece lip seal with success?
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | And the EBay link is “out of stock” do you have another source?
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | And the EBay link is “out of stock” do you have another source? That's because I just bought the last one that vendor had. Do a search for that part number (417210) seal and you'll find several. Six in stock with this vendor, at a somewhat higher price: https://www.ebay.com/itm/374410947588? I have bought six of them in the past few weeks. Prices vary widely for the same seal, so do your homework when shopping for one. Cosmo is running the seal that I fitted to his block, and I know of several others who have done similar installations. It takes me about one hour to do the machining, using a mounting fixture I fabricated for my Van Norman 944S cylinder boring bar. It bolts onto the back of the block using the same bolt holes as the bellhousing. Another advantage is that the seal lip can expand enough to allow the use of a a 3 7/8" "speedy sleeve" if the crankshaft seal surface is pitted or scored. I'm currently in the process of rebuilding a Van Norman model 777 dual speed, dual feed boring bar. It was a WW II production item, made for the US Army. Jerry
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | IHRL is this a possibility on the GMC Block?
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | I believe the GMC crankshaft has a flywheel flange that prevents a full circle seal from being installed in the proper location. The stovebolt crank has a straight flange that allows a lip seal to slip over the flywheel mounting bolt circle and contact the seal area. The same type of seal setup is used on the late model small block Chevy V8, beginning in the early 1990s, IIRC. Ditto for Ford Diesels, and Caterpillar V8 Diesel engines. Confirmed- - - -check out the flywheel flange on this GMC 270 boat anchor listed on Ebay: www.ebay.com/itm/372199684453?235 crankshaft- - - -the lip seal rides on the 3 7/8" diameter surface at the very back of the crank: www.ebay.com/itm/315239781392?Jerry
| | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | "If the block is stripped down to bare bones, it would be a good time to machine it for a full circle lip seal instead of a rope or 2 piece rubber seal at the rear main bearing."
Unfortunately, Jerry, the engine that will be pulled won't be stripped down to bare bones. Can't afford the machine work nor the cost to do a round trip journey. I've got the two piece rubber one which I was thinking was better than the rope. The engine I've promised to be waiting for you, however, except for the cam bearings, is.
How in the world does one capture quotes?
| | | | | Joined: Jun 2022 Posts: 558 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 558 | With a butterfly net??? Sorry... couldn't help it.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | To make the divots for the new style main bearings, the crankshaft will have to be removed- - - -no room to do the grinding for the tabs otherwise. It's about a 1 hour task to strip down a block, and doing anything else during a rebuild is a fool's mission- - - -too many places for bearing-destroying junk to hide. Bring it on- - - -I've seen what the ODSS crew can do when an engine buildup is in the works- - - -they make worker bees in a big hive look lazy by comparison! Jerry
| | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | Well, Jerry, I sure do hope you can be there. Not only to help move things along, but I'll be able to get rid of this torn down engine out of my garage AND, MOST IMPORTANTLY, your better half is doing better.
Jethro, thanks for the TREMEDOUS advise. Hey, while looking over your '54, noticed your grill has seen better days. Is it still like that? If it is, I'll have a white one that seems like it's in better shape in the very near future if I can get the clip off without messing things up. 0$
| | | | | Joined: Jun 2022 Posts: 558 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 558 | Thanks for the offer... but... I learned how to drive on this truck 60 years ago. It's the farm truck and has earned every dent and tear (many of which are mine.) I dare not alter its character. See you in Leonardtown.
Now, if you happen to have two 16" rims lying around...
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | Sorry, Jethro. The original rims were gotten rid of way back in '71. My brother went with chrome wheels, which the spare was stolen while in storage and I need a replacement for.
| | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | Is anyone bringing an engine hoist of some kind?
S2
| | | | | Joined: Nov 1995 Posts: 5,746 24601 | | 24601 Joined: Nov 1995 Posts: 5,746 | Stewart ... we're working on that ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | Reason I'm asking is cause I BELIEVE I have access to one. It's a "cherry-picker" type and will have to be put on a large trailer or towed. I just have to ask the owner. It's being stored in my yard.
| | | | | Joined: Nov 1995 Posts: 5,746 24601 | | 24601 Joined: Nov 1995 Posts: 5,746 | We have an engine hoist. A couple of tractors with front end loaders, too.
Thanks, though.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Stewart
Check your email. I sent you a message summarizing our discussion yesterday. For those in the same boat as you, here is the list of things to do before we come extract the truck:
1. Clear all items around the truck so it is accessible. 2. Make sure tires are aired up if possible. 3. Drain all fluids from engine and radiator. 4. Assemble engine stand.
Seeya Saturday!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | This is going to be one of those late night in the shop project, isn’t it? Oh boy!!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | I recall those days, listening for the frogs in the pond but mostly hearing "shop" sounds. Great memories.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | |
