| | | Forums66 Topics128,162 Posts1,056,910 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Trying to make vehicle more user friendly to the females in the household. Don’t tell me to keep it stick, that is just not an option. What needs to be changed to get rid of the 3 speed column shift and go to a column shift automatic. The engine is a 230 I-6. Does it require a bell housing change? What transmission can be used with the least amount of fabrication? This vehicle has some sentimental value to the female side of the family so a full on LS swap is not in the plans. What advise and words of wisdom can y’all provide. Thanks
| | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | The bellhousing will be part of the replacement auto transmission. Lots of options depending on overdrive or not. TH350, PG, TH400, 700R4, 2004R will all work. The last one we did was on a 64, the rear crossmember was removed and an aftermarket replacement was installed for the rear mount. Will need a flex plate, kick down cable, and an oil cooler either remote or part of a replacement radiator. A driveshaft modification will also be required. Fred
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Martin, where have you been? Missed you. Should be a "fairly" easy swap as Fred indicates. I don't know if 230 motor has side mounts or front. If front, you have to switch to side mounts. Anyway You can use a universal tubular trans crossmember. No welding required. Fred did not say how to handle the shift? Cable seems to be easier than linkage. A th350 is the best for your needs. you can do a lokar floor shift, very pricey. This is the best idea I've seen for DIY. Many have copied it and refined it. Basically welding forks together. Making a tooth "detent" plate and a "dog" tooth. Be sure to incorporate a Neutral Safety Switch (NSS). I'm sure the internet is full of info on "three on tree to automatic". Keep us updated on your thoughts and decision and questions.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 | Before you decide on the transmission, evaluate how much highway speed driving will be done and what your current rear gear ratio is. A numerically high (like 4.11:1) rear end used a lot for highway driving would probably be more comfortable with an OD transmission. If just used mostly for quick trips to the Dairy Queen a TH350 will do the job.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | Any automatic transmission from a Chevy V8 equipped vehicle used from the mid 1960's to the early 90s will be a bolt-on fit to the 230/250/292 six, with nothing but a flywheel change and possibly a different starter. The bellhousing shape is the same on the sixes and 8s (even the Mercruiser 4 cylinder) from 1963 and up. I'd suggest a simple TH 350 3 speed. They're rugged, easy to rebuild if necessary, and pretty plentiful. The TH400 consumes too much power internally- - - -it was designed for heavy vehicles and high torque V8s- - - -Buick , Olds, Cadillac, big block Chevy, etc. A 400 is also about 50 pounds heavier than a 350. RUN- - - - -do not walk away from the 700R4 and/or the 2004R transmissions- - - - -they're an unreliable PITA! A 4L60 requires an expensive stand-alone computer controller, since it has shift solenoids that are controlled by the vehicle computer on later model applications- - - -1990s and up, IIRC.
A TH 350 will be the simplest way to besome a "shiftless Okie! LOL! Jerry
| | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | I'd RUN- - - - -do not walk away from the 700R4 and/or the 2004R transmissions- - - - -they're an unreliable PITA! A 4L60 requires an expensive stand-alone computer controller, since it has shift solenoids that are controlled by
A TH 350 will be the simplest way to become a "shiftless Okie! LOL! Jerry I'd second that!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Thanks everyone for your insight and advice. Probably a Fall project. Will have to find an automatic column to swap out. I have a TH350, flywheel, torque converter and flex plate out in the container.
| | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | A properly built and adjusted 700r4 or 200 4r are good transmissions. People that don’t adjust the TV cable properly and never service the fluid in them make them get a bad rap. | | |
