3 members (TooMany2count, Bill Hanlon, Gray_Ghost), 32 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#154379 08/16/2007 12:47 PM
I can't find it. This is about the 195? 1 ton dump truck, but probably applicable to the 1951 4400 as well.
I've read many times that there is a VIN number stamped into the frame about two feet back from the front of the driver's side frame rail. Since the engine and cab are not original, I was going to find the frame VIN before I transferred the title.
I looked at as much of the frame rail as I could see through the driver's side fender opening, but didn't see any numbers at all. What side of the frame rail is it on?
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
#154380 08/16/2007 1:38 PM
The AD trucks (47 to 55.1) did not have any "VIN" (no such thing as a VIN in the 50s) number on the frame. The only numbers on the truck were the manufacturer's ID plate on the door post and the engine number on the passenger side of the engine. When your truck was originally titled in the 50's, depending on the state, it would have been titled with one of those two numbers. My 53 was purchased in Cape Giradeau, MO, and was originally titled with the ID number from the door post.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#154381 08/16/2007 2:44 PM
to relieve yer puzzlement stark, concerning "I've read many times ...", they started stamping a "vin" on the frame of the Task Force series
#154382 08/16/2007 8:40 PM
I've seen some of the heavier Art Deco Trucks, with the Serial Number stamped on the left frame rail, to the front of the front spring hanger, but never on a Advance Design truck.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#154383 08/17/2007 1:32 PM
Sorry about referring to it as a VIN. The problem is that the cab is from a 1952 3/4 ton and the title has that ID number on it. I wouldn't really care if the truck was a '47, or a '54, but I'd like to know because there are some differences in the parts used.
#154384 10/21/2007 12:28 AM
so spanky
what is a heavier art-deco? i just acquired a 41-46 chevy bus. the plate on the side of the cowl is way past reading. forensic science mayby. it has a 195"? wheel base. 2 ton? 7 windows. 28 passenger? i would love to know what year it is. and if anybody feels the need to tell me anything about these things, go ahead on!! i'm all ears. can use all the help i can get!!
thanks yall
alton
alton
#154385 10/21/2007 3:07 AM
When I say Heavier Art Deco Trucks, I'm referring to the 3 ton, & up trucks, of the GMC line of trucks. Chevy didn't make, what was considered "Heavy Duty" trucks until 1956. Everything before then, (1 1/2, & 2 ton) was considered "Medium Duty".
Spanky Hardy
1950 GMC 250 1-Ton
