Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (1955 1 Series, Peggy M, Jon G), 49 guests, and 4 robots.
Topics128,009
Posts1,055,296
Members48,419
#1543347 04/09/2024 4:47 PM
New member here.
I just purchased a 1954 Panel Van (big project) and would like help identifying the engine that’s currently in it. Thank you in advance for any help you can offer.
VIN - L54K226652.
Stamped number on the pad behind the distributor - F929J.
Intake cast-in number - 37544844.
Head cast-in number on the drivers side - B49 848, below the 848 is 850.
Head cast-in on the passenger side -383 6848, below 6848 is GM 18.
Thanks, Dennis
Authorized Pest
Authorized Pest
P Online: Content
Dennis, glad to see you've posted. Engine ID is something the Stovebolt Collective can help you with. Details on what you provided will be coming soon. wink ITMT, here's a Legacy Tech Tip that may help out: Identifying the 216 / 235 / 261.
~ Peggy M
1949 Chevrolet 3804
Thank you !!
Dennis... look at the intake again. See if it isn't 3754644.
You are in moderated status. You need 5 posts (4 or 5, I forget) then you will be a full bolter and have full access to this site. Shoot me an "OK" for your 2nd post. Look around the starter area for the block casting date code. Post that. Look under the fuel pump area for the block casting #. Should be another 383xxxx. Post that. Then post a HAHAHA! AND YOU WILL BE GOOD TO GO.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
The numbers you posted point to a 59 235.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
Authorized Pest
Authorized Pest
P Online: Content
Jethro ... close. After the 4th post, the newbie is out of "moderation" but it doesn't show up under his name as "Bolter" until that 5th post is made. (Doesn't really make sense but that's what happens.) On *our* end, we (Moderators) don't have to approve any of his posts after he does the 4th one.
As far as the access to the entire site, he does have access. He can even read a PM from you but he would not be able to respond. He'd get a message saying:
"You cannot add any more replies to this private topic at your current member level."
Once he reaches 'Bolter member level (following 4th post), that statement is removed and he can respond to any PMs.
When a newbie first arrives at the doorway, we try to follow him and approve the posts quickly as they come in. At times, we've engaged enough (seeing that he's online) to post answers to short questions so he'll get that 4th post in.
I'm sure you all will be able to help him ID the engine. Hopefully, walk him thru (or show him the link) on how to post images, if he needs that help, too.
~ Peggy M
1949 Chevrolet 3804
Jethro, the number could very well be a 6. (3754664). I will try and post pictures of the engine and the numbers.
Peggy, thank you for the clarification on the new member rules.
Dennis
Authorized Pest
Authorized Pest
P Online: Content
Now that you know the ins and outs, YOU are no longer moderated. Next post, you'll see that 'Bolter tag show up under your name. thumbs_up
~ Peggy M
1949 Chevrolet 3804
VIN L54K026652 breaks down as follows
L = 1-ton commercial
54 = Year
K = Kansas City Assembly Plant
026652 = unit number starting with 001001
Your engine serial number F929J breaks down as follows
F = Flint Engine Plant
9 = Month (September)
29 = Day
J = truck (depends on year as to which model it would be in)
This engine code format was used from 1957-59. To zero in on the actual year you need to look at the casting date code location behind the distributor. It will look something like this H 15 7 (Month/day/year).
Edited in RED, I corrected my first post where I had the plant and models backwards, sorry for the confusion...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Attempt at posting pictures.
Intake
Stamped ID near the distributor
Cast code below Distributor.
More pictures.
Let me know if there is something else i can post a picture of to help out.
Thank you.
Cast code on passenger side
Cast code on head, drivers side.
The block and head will have casting date codes like I mentioned in the above post...those will help tell you what year they were made as the same cast part number was used for many years.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Apparently I’m terrible at typing numbers in so the pictures should clarify.
Sorry for the confusion.
Block below distributor
VIN number
Your second set of pictures with the B49, 848 and 850 numbers are foundry numbers for the sand castings needed to make that head. They don't mean anything to us now.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I’ll keep looking, Thanks
Authorized Pest
Authorized Pest
P Online: Content
Dennis, you are not only good at posting pictures, *I* am impressed that you've got titles with your images. Those are so helpful. Thanks for taking the time. Aren't pictures great. grin
~ Peggy M
1949 Chevrolet 3804
I corrected my first post above in RED, sorry for the confusion, I had the plant and model backwards.
026652 is your assembly plant number starting with 001001, so you have the 25,652nd unit out of plant K.
Mike B
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Does this do us any good?
It’s behind the starter.
This number is behind the starter.
Thanks Peggy,
It took me a number of tries before I succeeded.
Authorized Pest
Authorized Pest
P Online: Content
Dennis, it did for me, too. I'm on a PC using a bunch of windows at a time. I found dragging and dropping is easiest for me. If you see any of the instructions need some more 'splaining, just send me a .... PM!! grin
~ Peggy M
1949 Chevrolet 3804
Thank you Peggy for your help and the link.
Dennis
Originally Posted by DennisN
Does this do us any good? It’s behind the starter.
CON 3 = Conveyor used in the foundry during the casting process.
I 26 8 = Casting date;
I (eye) = Month (September)
26 = Day
8 = Year (1958)
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Great !!!
Thank you very much Mike !!!!
