2 members (dt235sd, Southerntruck), 145 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#1543192 04/08/2024 1:50 PM
Sorry if this has been asked a zillion times already, But, does anyone know there you can send in a steering box to get rebuilt?
Thank you in advance!!
Steve Elliott
Steve, Your question will surely get some answers soon, but the topic better falls into the Driveline forum so it has been moved there. wink
~ Dan
1951 Chevy 3 window 3100
Can you pull the steering wheel and notice in and out play? Is there slop turning left and right before the wheels start to turn? Have you tried making these adjustments? There is a tutorial on this site explaining the process. You may not need a "rebuild."
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
If you do need your box rebuilt, Lares does an excellent job. They'll even change the gearing if you want them to from 4 turns lock to lock to 3 turns lock to lock.l I had them do a standard rebuild on the box for my '76 F-150 8 years or so ago.
www.larescorp.com
1950 Chevrolet 3100 (Ol' Roy)
Before I ever even look at a steering box, let alone try to adjust it, I always check every steering component downstream of the gearbox.
A brand new steering box won't make a vehicle ride any better if you have worn out drag link ends, tie rod ends, kingpins, loose wheel bearings, worn out leaf spring bolts and hangers, or bad tires.
i found information on adjusting my 1950 chev 3100 steering box and took alot of play out of steering , but once done i had to adjust the steering wheel by removing it and put back to center. now it drivers alot better. but in a few miles i will let it break in and readjust steering box.
What make/model/year are we talking about?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
1953 Chevrolet 3600 3/4 ton. I decided to go ahead and replace my front leaf springs, they are shot!!!! Also replacing the front shocks, and replacing the king pins.Everything else is new. Drag link, Tie rod ends, and wheel bearings. Hoping it will make a big difference.
Elmo #1543553 04/11/2024 12:57 AM
It will make a huge difference.
The can of worms is now open. You'll probably want to replace the rear springs and shocks now too, if they're as worn out as the front ones.
For the sake of a learning opportunity for all of us, can you give it a thorough test drive now, before you do anything to the steering box?
I am curious just how much improvement you have accomplished with what you have done thus far.
I will keep all of you in the loop when I finish.
