1 members (Otto Skorzeny), 74 guests, and 1 robot.
Topics128,132
Posts1,056,730
Members48,454
#1542189 03/29/2024 3:35 PM
back yard wrench turner
Carbking. Jerry 'Hotrodlincoln' suggested I contact you about this issue.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Carburetion specialist
What kind of carb?
Jon
The Carburetor Shop
carbking, Zenith 11968 for my GMC 270 Cubic Inch. I have the carb, it seems to seep even after having been rebuilt.
Wayne
1989 Silverado
How much of a seep?
Not uncommon for modern fuel to "wick" through a gasket.
Is the intake wet, or just some stains on the carburetor?
Jon
The Carburetor Shop
O Online: Content
I wonder if the mating surfaces are warped.
1950 Chevrolet 3100 (Ol' Roy)
Originally Posted by carbking
How much of a seep?
Jon
It was dripping onto the intake before I removed it. It's sitting on the shelf now. But I would like to use it again. I feel the bowl is porous.
I'll put some gas in it and let it sit. Then I can give a better response.
Wayne
1989 Silverado
Where and when was it dripping?
Take a look at the link to my website about leaks around the throttle shaft:
Leaks around throttle shaft at engine shut-down
Jon
The Carburetor Shop
Wayne - the reason for all the questions is to attempt to determine if you really have a porous carburetor.
The only carburetors of which I am aware that have a reputation for being porous are the new imitation AFB 4-barrels. I won't mention the name of the company selling them as that might trigger a "Peggy attack" on the thread wink (Not a complaint Peggy, I respect the work you do, and the line you have to not allow us to cross).
Your carb is a Zenith type 228. Not saying that one doesn't exist, but I have never seen a porous type 228.
I would not be afraid to try your Zenith again, and try to determine where and when it is dripping.
But to answer your original question:
Carburetors constructed of brass or cast iron, IF SUFFICIENTLY VALUABLE, could be glass-beaded, dunked in a degreasing solution, rinsed, again glass-beaded, and soldered, or nickel-plated to fill a leak.
Carburetors constructed of aluminum can be TIG welded.
Carburetors constructed of zinc alloy ("pot metal") such as your Zenith may be replaced.
Jon
The Carburetor Shop
Jon, I filled the bowl with gas this morning. It's been about 6 hours and I don't see any gas dripping or seeping.
I need to put it back on and then pay closer attention of where the leaking fuel is coming from. It
will be a couple of days before I wil have time for this.
I'll report back once it's back on.
Wayne
1989 Silverado
