3 members (Leo, treegrower, Eisenholtz), 103 guests, and 2 robots.
Topics128,140
Posts1,056,774
Members48,454
#1542189 03/29/2024 3:35 PM
back yard wrench turner
W Online: Content
Carbking. Jerry 'Hotrodlincoln' suggested I contact you about this issue.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Carburetion specialist
What kind of carb?
Jon
The Carburetor Shop
W Online: Content
carbking, Zenith 11968 for my GMC 270 Cubic Inch. I have the carb, it seems to seep even after having been rebuilt.
Wayne
1989 Silverado
How much of a seep?
Not uncommon for modern fuel to "wick" through a gasket.
Is the intake wet, or just some stains on the carburetor?
Jon
The Carburetor Shop
O Online: Content
I wonder if the mating surfaces are warped.
1950 Chevrolet 3100 (Ol' Roy)
W Online: Content
Originally Posted by carbking
How much of a seep?
Jon
It was dripping onto the intake before I removed it. It's sitting on the shelf now. But I would like to use it again. I feel the bowl is porous.
I'll put some gas in it and let it sit. Then I can give a better response.
Wayne
1989 Silverado
Where and when was it dripping?
Take a look at the link to my website about leaks around the throttle shaft:
Leaks around throttle shaft at engine shut-down
Jon
The Carburetor Shop
Wayne - the reason for all the questions is to attempt to determine if you really have a porous carburetor.
The only carburetors of which I am aware that have a reputation for being porous are the new imitation AFB 4-barrels. I won't mention the name of the company selling them as that might trigger a "Peggy attack" on the thread wink (Not a complaint Peggy, I respect the work you do, and the line you have to not allow us to cross).
Your carb is a Zenith type 228. Not saying that one doesn't exist, but I have never seen a porous type 228.
I would not be afraid to try your Zenith again, and try to determine where and when it is dripping.
But to answer your original question:
Carburetors constructed of brass or cast iron, IF SUFFICIENTLY VALUABLE, could be glass-beaded, dunked in a degreasing solution, rinsed, again glass-beaded, and soldered, or nickel-plated to fill a leak.
Carburetors constructed of aluminum can be TIG welded.
Carburetors constructed of zinc alloy ("pot metal") such as your Zenith may be replaced.
Jon
The Carburetor Shop
W Online: Content
Jon, I filled the bowl with gas this morning. It's been about 6 hours and I don't see any gas dripping or seeping.
I need to put it back on and then pay closer attention of where the leaking fuel is coming from. It
will be a couple of days before I wil have time for this.
I'll report back once it's back on.
Wayne
1989 Silverado
