1 members (J Lucas), 40 guests, and 4 robots.
Topics128,014
Posts1,055,324
Members48,419
#1539839 03/11/2024 2:48 PM
If someone could help me ID this 235 engine I would really appreciate it. The serial number on the boss appears to be F606H
Thank you!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Do you see a cast # near the starter?
BC
1960 C60 pasture art
Chuck, as BC mentioned knowing the block casting number will help define what it is. If we just use the stamped serial# shown, according to the 1957 Chevy Truck data PDF, your numbers indicate it should be a 1957 built June 6th and installed in a 1/2 - 1 ton truck (see screenshot below).
~ Dan
1951 Chevy 3 window 3100
Thanks BC and Dan for helping me with this request. I always thought the ser. # was the most informative of the #’s. Honestly Dan, you gave me all the information I really needed.
Thank you again!
Chuck
1941 Chevy coupe
~ Dan
Hey there Dan (or somebody!), because you’re so good at identifying motors I’ve got one more for you to help me with if you would please. Please see attached photos.
Thanks so much!
Last edited by Peggy M; 03/27/2024 8:53 PM. Reason: Dan may be out of pocket a bit today ... ;)
Chuck
1941 Chevy coupe
F- - - -Flint Michigan
54- - - - -1954 production
Z- - - -standard transmission
1954 235 engine for a standard transmission vehicle, assembled in Flint Michigan.
https://chevy.oldcarmanualproject.com/models/engine.htm
"Z" = 235 car engine..."X" = 235 pickup truck engine.
E 28 4 = May 28, 1954 casting date.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Chuck, Jerry and Mike B gotcha you covered sir. 👍
~ Dan
Thanks Jerry and Mike! To be clear, the “Z” suffix tells me it’s a car engine, correct? If so, I know the engine mounts are different and if I want to put it in my ‘50 truck I’ll have to install truck mounts. Is that difficult to do? I wouldn’t think holes would already be in place where truck mounts would have to be installed. Help understanding appreciated.
Chuck
1941 Chevy coupe
The truck front mount is a rectangular rubber and steel assembly that bolts to the flat bottom of the steel separator plate between the engine block and the timing gears. It might be necessary to drill that plate for the mount attaching bolts. Some are drilled- - - -others aren't. Use the mount as a template to locate the holes.
Chuck, Just a little pointer to an already existing Tech Tip on converting a 235 "car" motor front mount to truck use. All the details you need to modify that front engine plate to front mount use in your truck! wink Happy drilling! smile
~ Dan
Thanks Jerry and Dan. I wasn’t aware that there was a tech tip on the mounting subject, so I’ll read that tonight. Sounds from Jerry like there might be a remote possibility that the front holes could already be there in this car engine I’m considering buying, so I’ll ask the owner to check for me.
Thanks again for all the help!
Chuck
1941 Chevy coupe
Having to swap out the front plate might be a good thing, gives you a chance to pull the pan off.
BC
BC59, not that easy... take the pan off to remove the timing cover, then find the plate is behind the timing gears. No go.
Just drill the holes. I did.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Correct, "Z" = car engine...
Mike B
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I know what's involved, I'd just as soon see what's inside before installing it in a rig.
BC
