2 members (moparguy, Gray_Ghost), 109 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
What are the spring specs? Mine is gone.
AD Addict & Tinkerer
Moved post to start new thread. This will address the new question and avoid confusion with the OP’s question.
Phil
Project Journals
Stovebolt Gallery Forum
What you really need to do it right is a part number for your Delco-Remy distributor and a D-R spec book (see a page below - I borrowed the book from a friend). Then you'd need a Sun distributor machine or if you're poor like me, a set back timing light, a MityVac vacuum pump (if your distributor has a vacuum advance), a tachometer (some timing lights have one built in) and a running engine to spin the distributor.
There you go again, Bill- - - -injecting logic and reason into a perfectly good hunt for a unicorn! There's a whole box of those springs sitting under the leprechauns' pot of gold at the end of the rainbow!
LOL!
I think maybe I’d rob the springs out of another junk distributor. Or just find a different distributor.
1951 3100
