2 members (Otto Skorzeny, Roy Rodgers), 103 guests, and 3 robots.
Topics128,042
Posts1,055,518
Members48,424
What are the spring specs? Mine is gone.
AD Addict & Tinkerer
Moved post to start new thread. This will address the new question and avoid confusion with the OP’s question.
Phil
Project Journals
Stovebolt Gallery Forum
B Online: Content
What you really need to do it right is a part number for your Delco-Remy distributor and a D-R spec book (see a page below - I borrowed the book from a friend). Then you'd need a Sun distributor machine or if you're poor like me, a set back timing light, a MityVac vacuum pump (if your distributor has a vacuum advance), a tachometer (some timing lights have one built in) and a running engine to spin the distributor.
There you go again, Bill- - - -injecting logic and reason into a perfectly good hunt for a unicorn! There's a whole box of those springs sitting under the leprechauns' pot of gold at the end of the rainbow!
LOL!
I think maybe I’d rob the springs out of another junk distributor. Or just find a different distributor.
1951 3100
