2 members (klhansen, 1 invisible),
151
Mod | | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15416 01/28/2002 1:02 PM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | How do you tell the difference between: 1937-1940 Carter w-1 1941-1948 Carter w-i If you had one each of these laying side by side how can you tell the difference. Thanks now for any help you can give Mike | | |
#15417 01/28/2002 1:05 PM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | Carter w-1 identifiers I would like to add for the 216 engine sorry Mike | | |
#15418 01/28/2002 8:00 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Just give me the "casting number" from them and I will identify them for you.Not the part number tag- but "casting number, located on face of carburetor flange.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#15419 01/29/2002 2:47 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Oly , I 'm delighted to see you can I.D these carbs . I have one with 421 on the base , the other is 396 I think . Do you list those ? | | |
#15420 01/29/2002 3:24 AM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | Oly thanks for reply I am a new guy and thought I would be ignored. Just insecure i guess but goes to show how good this forum is.
Now to the point I have a Carter YF I cant identify. the bowl is not cast is has x2207 the base is cast and has a 1-830 on it. I have looked several times and it could possibly be 1-630 but I think it is 1-830 It is not marked the same way as a W-1 with a recessed # in the cast bowl. So I could use help on identifing this YF carb.
Now to the original problem on the difference between a 37-40 and a 41-48 W1 with the same cast # on it is what I needed to know. I found that answer the 37-40 is not vented . the 41-48 is vented with a accelerator rod running upward. The 49 and up have an additional rod running upward for the choke. This is what it took me all day to find out. Now I am ready to see if the experienced agree or not. And Oly I need identy on the YF Thanks Su per long huh?? | | |
#15421 01/29/2002 6:16 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Ok- the book the wife bought me deals with carbs from 35-47, but the good news is I can identify two of the carbs (one from the book, the other from memory) for you all. For others I'll need better numbers, better books or a better memory(LOL). Dusty, your #421 is for a 41-42 chevy. Loebig, your YF as I recall was on 50-up Nash and 50- Willys. Make that a 99% 50-up Willys. The casting number has to be 630. Seen to many to forget- I'm just slow. I cann't locate a w1-396, Dusty, Sorry. Loebig, if you are refering to the "Anti-percolating Unit", then you are correct.
OK, I'll bite.-- HOW are you, Loebig, a new guy, when you are Member #903 and have 32 posts?-- Inquiring minds would like to know-- MINE.(LOL)
[ 01-29-2002: Message edited by: oly ]
#15422 01/29/2002 12:48 PM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | I guess I am new to the posting and answering. I do mostly watching and haven't had to ask any questions. The knowledge on this board is terrific. I have increased my knowledge by listening closely. My previous knowledge is working in a salvage yard in the early 60's. As an example in the 60's as far as the 1948- 1954 chevy trucks are concerned I would take the parts off for the customer when they came in. The heaviest hitters on these trucks for wanted parts were in order. 3 speed transmission.inside door handles,starters,generators. I think the starters related to the cold winters in Minn. So my truck has a 4 speed 12 volt alternator. I never had a call for a 4 speed trans. they are one tough unit. thanks again Mike | | |
