6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#1541545 03/24/2024 9:50 PM
Good afternoon gang, I have a 1953 3100, with a 1955 235 and an aftermarket aluminum radiator. The side radiator supports have 2 rods that run from the upper part of the support down to the plate behind the bumper. I see these in technical drawings and they look original.
Mine also has 3 more rods welded in. 1 across the bottom side to side and 2 more diagonally top to bottom in the same channel, forming an x across the front of the radiator. Are these original?
Yes. Those are factory
1950 Chevrolet 3100 (Ol' Roy)
It depends. My radiator support (and the old one I got to replace it) had those diagonal rods, but I've seen supports without the diagonals. I suspect that yours is original. But the FAM, which shows '53 and '54 stuff has a figure (dated 5/53) of the radiator support without them. I don't think it matters whether they're there or not.
Mitch, The 2 snapshots from my 1947-54 Factory Assembly Manual show all those rods in place same as yours. Hope that helps. 😉
~ Dan
1951 Chevy 3 window 3100
Kevin beat me to the post button - lol! 😉 Working on my phone slows me down due to stubby finger typing - argh.
Which diagrams from the FAM did you find for a reference Kevin???
~ Dan
Dan, the FAM figure I found was Section 13, Sheet 1.00, but I see now that it only pertains to 3742-3942 models, which are bare chassis produced for the forward control vans.
I hear you about working thru the phone peephole. I'm surprised you were able to attach the figures that quickly.
Leo Offline
Moderator
Moderator
I had those in my 1953 3100.
Thank you! I appreciate the info.
Got 'em on my 54 3100
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
