| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | What bolt pattern do 1950 1KRs have? Or were there optional wheels. Come to think of it, searching for 1KR doesn't produce any hits. Its a 1950 1 ton dump truck.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | This is a Chevy or GMC 1-ton? If so I would expect to find the same 8-lug pattern that is on a 3/4-ton.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Sorry, its a Chevy. One of the reasons I am considering the purchase is that my 1951 Chevy 4400 needs seven new rims. Whats the bolt circle and offset on the 8 lug rims? (Sorry, I'm lazy.)
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy starkweatherr, I believe that a 4400 uses wheels that have 10 holes, they only use 5 studs on the front, 10 studs on the rear, hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | a 1 ton AD will have 8 lugs. as far as wheel size, If Single wheel then 17" is the usual size, and if dual then 18 is the normal.
For replacement wheels for a 4400 you should look at an AD 1.5 or 2 ton. These will be lock ring type 20" if stock. Be sure to check the center hole diameter before you buy. The earlier wheels have 4.75" and later have 5.25". I am guessing you have the 4.75"?
Grigg | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Grigg, I'm not sure I understand. I'd like to get away from 'widow-makers' and tubeless tires. I've even considered Budd style wheels, but it looks like I'm still looking at $200 per wheel for the hub mount type, that would still have to be converted.
Frankly, the wheel issue, combined with my lack of money, has soured me a little on the 4400.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | So, I am a little confused too. Are you looking for wheels for a 1 ton dual, or a 1.5 ton?
Sounds like the goal is relatively inexpensive easy to find single piece wheels and tubeless tires?
If 1 ton then the answer is simple, easy, and relatively cheap. Eight lug dual 19.5" wheels from a bread truck and 8R19.5 tires.
If 1.5 ton then it is not as easy. Ten lug 19.5" wheels from a slightly larger bread truck will work, although check the center hole diameter, as a set of simple spacers may be needed, the new wheels have a 5.25" hole... These wheels fit the 8R19.5 tries also, but they are several inches shorter than the original tires. I think they look to small on a 1.5 or 2 ton. The other, in my opinion, most desirable, option is a set of 10 lug 22.5" wheels from a 56 Chevy 1.5 ton. Same deal with the 5.25" center hole. They are not real easy to find, although prices are generally fair if you do find some. Many tire choices are available, and 9R22.5 is probably a good one, comparable to 8.25X20.
Any more clear?
Grigg | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Sorry, I forgot to mention that I bought another truck. I don't know exactly what it is, but it is supposed to be a 1 ton, it has duallies with 18" rims, a five window cab from a 1952 3/4 ton and a 1954 235 engine. It is noticeably smaller than the '51 4400, but the frame looks like it might be a factory 1 ton model.
For that one, the 19.5s would be perfect, especially since it runs, kind of, and the dump works, except all the levers are broken off. In other words, I plan on having it on the road by late tomorrow. :rolleyes: Very late.
For the '51 4400 I guess I just need to keep looking. Naturally, I told my wife that I'd sell the '51 to make room for the other one, but we all know how guys lie about trucks.
Would the '56 1.5 ton tires be tubeless?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Originally posted by starkweatherr: Would the '56 1.5 ton tires be tubeless? Yes, they may have had tubes, but they can be run tubeless with new tubeless tires. I have a set of 6 8X22.5 tires that would be great for an around the county work truck, great tread. I don't need them as I will have new radials on my truck when I get that far. I think I have an add in the parts for sale section for them. Grigg | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 |
