9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible), 125 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
#15411 12/09/2004 6:09 AM
Junior Member
Junior Member
My 235 in our 1957 Blue Chip Fork lift is so sad, previous owner ran it without air filter, all kinds of critters went through it, so no compression; what can I swap to with same bell housing bolt up pattern, 261, 29...? Have located a 1972 235 with great compression still; will it it bolt up?
#15412 12/09/2004 6:45 AM
There are a lot of good 216s being pulled and discarded and would work great in a forklift.
216, 235 and 261 all share the same bolt pattern on the rear. 1942-62 share the same flywheel bolt pattern.
The 1972 engine you are looking at would be a 230 or 250 not a 235 and uses a diferent bellhousing and flywheel.
My Blog
#15413 12/09/2004 7:02 AM
V
V Offline
Don't give up yet ! untill you've done a full tune up and valve adjustment , I always hear
" yes, I checked the valves " ~ B.S. ! every one I work on has tight valves and so won't run correctly .
It only takes a couple hours to adjust the valves then set dwell & timing , even with 60 # compression these old things run pretty well .
' Blue Chip ' forklift eh > musta been mighty expensive when new , most forklifts i;ve ever seen had four banger flatheads . or is it just BIG ? .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
