5 members (Peggy M, Uncles51, JW51, Millenimech, Chip O), 61 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#154103 08/01/2007 12:58 AM
I know I've seen in a post a website listed for models of Browni's, but I can't seem to find it.
I have a Model 42, Watson Transmission, Serial # 7 82530. Where do I find out the ratios, and whether it's an underdrive, or overdrive or combo? Obviously I don't know much about them.
Terry Wofford
'52 GMC 3 1/2 Ton
'51 GMC 2 1/2 Ton
'53 GMC 1 1/2 Ton
'53 Chevy 2Ton
"If it ain't broke, well give me the keys and I'll be right back!"
#154104 08/01/2007 2:28 AM
check oldgmc.com grigg posted a list of several brown lipe transmissions. not sure of the watson connection
#154105 08/01/2007 4:24 AM
I don't have much info on the Watson, but tons on the Spicer auxiliary transmissions.
The best way to see what ratios you have is start turning the input, count both the input and output revolutions and divide.
Or count gear teeth and divide.
You will have a direct or 1:1 gear as one choice.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#154106 08/05/2007 4:36 AM
Is it a 3 or a 4-speed? Most Brownlipes had the direct in the 2nd-highest position. The 2 around it were a short under- and overdrive, and the 1st on 4-speeds was 60 or 90-under; a deep-reduction gear.
1951 3800
-hotshoe
#154107 08/10/2007 1:29 AM
hotshoe36, the box isn't in a truck right now, and I haven't had time to figure it out yet. I do need to get back and pick up the linkage/shift rods that are still sitting on the back of on old truck I traded for. The fellow said what I didn't want back there he would just drop off at the dump.
Terry Wofford
'52 GMC 3 1/2 Ton
'51 GMC 2 1/2 Ton
'53 GMC 1 1/2 Ton
'53 Chevy 2Ton
