0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 41 | I know I've seen in a post a website listed for models of Browni's, but I can't seem to find it. I have a Model 42, Watson Transmission, Serial # 7 82530. Where do I find out the ratios, and whether it's an underdrive, or overdrive or combo? Obviously I don't know much about them.
Terry Wofford '52 GMC 3 1/2 Ton '51 GMC 2 1/2 Ton '53 GMC 1 1/2 Ton '53 Chevy 2Ton "If it ain't broke, well give me the keys and I'll be right back!"
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | check oldgmc.com grigg posted a list of several brown lipe transmissions. not sure of the watson connection | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't have much info on the Watson, but tons on the Spicer auxiliary transmissions.
The best way to see what ratios you have is start turning the input, count both the input and output revolutions and divide.
Or count gear teeth and divide. You will have a direct or 1:1 gear as one choice.
Grigg | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Is it a 3 or a 4-speed? Most Brownlipes had the direct in the 2nd-highest position. The 2 around it were a short under- and overdrive, and the 1st on 4-speeds was 60 or 90-under; a deep-reduction gear. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: May 2005 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 41 | hotshoe36, the box isn't in a truck right now, and I haven't had time to figure it out yet. I do need to get back and pick up the linkage/shift rods that are still sitting on the back of on old truck I traded for. The fellow said what I didn't want back there he would just drop off at the dump.
