0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | I have installed a 292 using the side engine mounts and was wondering if the bell housing crossmember was necessary if I used the T5 tranny crossmember or are both required? Not using the bell housing crossmember buys more clearance for brake booster, clutch mc and exhaust but it sounds questionable to rely on the T5 crossmember. Thanks in advance!
1950 Chevrolet 1/2-Ton 3100
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | If you're still using the conventional straight axle and leaf springs, the cowling crossmember is definitely still needed. It braces the frame where the rear spring hangers are attached. If you've butchered up the frame with an IFS of some sort, the cowl crossmember probably isn't all that important- - - -the geometry and stability of the original frame has been permanently compromised anyway. Jerry
| | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | Jerry, I still have straight axle and leaf springs with all original crossmembers in place...well the bell housing X-member is from later truck that accepts a 292 but other than that all the same. Thanks
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I believe the general rule is front mount/bellhousing mount OR side engine mount/tailshaft mount. Like a triangle pointing forward or the triangle pointing rearward. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | There won't be a way to do a front mount on a 292- - - -there's really not much of an attachment point at the front of the block where a front/center mount can bolt on. Jerry
