| | | Forums66 Topics128,133 Posts1,056,395 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Hey Guys, '49 truck re-wire / 12 volt. one of the last things I need to do in the re-wire in installing the voltage reducer to use the stock gas gauge. I'm using the light duty reducer that looks like a block of (asbestos?) with a wire on each end. No issues soldering in, my question is mounting. I'd figure to encase it in shrink wrap- that ok? Or do I just protect the leads, & it doesn't matter what the body of the reducer touches? Thanks in advance Rick voltage reducer | | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | Hi Rick, A lot of electrons have been sacrificed here to discuss that topic. That is just a common resistor. I would not encase it in anything but I would protect the leads and try to have the resistor not touch anything. Hopefully it won't (given the small current draw of your fuel gauge) but that type of resistor is likely to get hot in operation, so you don't want anything to insulate nor hold heat in. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Thanks J !! I figured as much | | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | It's done & came out great. Now if I can just figure out how to post pictures | | | | | Joined: Feb 2019 Posts: 4,483 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,483 | Here’s a link to instructions on how to add pictures to a post.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Oh and lookie there ... just to the left of Phak's post ... if you see the left column (if you don't, you're missing a few treats!  )
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
