1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 806 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 806 | Newly rebuilt motor & head was serviced (I don’t know exactly what he did). He did not paint it & I don’t think it was boiled out. All I saw was fresh grease on the lifter etc. I have put a couple of hundred miles on it. I just noticed this morning that bluish smoke blows out when I hit the throttle quickly. I drove her 10 minutes after she warmed up good. It still smoked when I returned. I don’t see any drop in oil level lately. Will it do that before the rings seat? 1953 Chevy 153A 3/4-tonWorking on my project since 2015Follow along in my DITY | | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 |
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Aug 2015 Posts: 806 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 806 | Oops it has used oil, maybe half a quart, at least from the full to add mark.. That clean oil is difficult to see on the dipstick! 1953 Chevy 153A 3/4-tonWorking on my project since 2015Follow along in my DITY | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Do you know who rebuilt it? Some folks' idea of "rebuild" differs from what is correct. A sloppy cylinder boring/honing job will make it difficult for the rings to seat with the cylinders. If it were mine, I would drive it on a road where you can safely work up to 50 MPH and let off the throttle down to about 40, and keep doing that over and over again. It's hard to tell how long you will need to do this to seat the rings. Too many variables. The reduction of smoke is what you need to look for. I have had two 235s completely rebuilt without cutting any corners and neither of them smoked or consumed oil. I realize that your engine is a 250, but the same principal applies even with a push lawn mower engine.
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I realize that your engine is a 250, but the same principal applies even with a push lawn mower engine. Kinda hard to get a push lawn mower up to 50 MPH to seat rings.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | I wonder which valve seals he used, or if guides were replaced. | | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | Sounds like a candidate for Bon Ami. Dad had bought a new D6 Cat back in '48 that burned oil excessively. The Caterpillar rep came to the field in a business suit and sprinkled Bon Ami into the intake with 2 fingers several times then let the engine run for about 10 minutes. Told Dad to "Shut her down and change the oil." It never burned another quart of oil after that. The Bon Ami scored the cylinder walls just enough for the rings to seat. That D6 was still pushing earth when he sold it in '98. Gotta be Bon Ami, it's a finer grit than Comet or Ajax and only works on new or newly rebuilt engines.
