6 members (DavidBraley, Maybellene, Gray_Ghost, Otto Skorzeny, Paul Mullen, Gdads51), 98 guests, and 6 robots.
Topics128,185
Posts1,057,200
Members48,465
Please see enclosed picture. The hole on the right side of the picture... to the left is the transmission cover opening, on the right is the battery cover... what is the purpose for the hole in between, the one just above the two horizontal protrusions? I tried to find it in the FAM but failed. FYI, this is a replacement floor. Many thanks.
1952 Chevy 3100
Original floor does not have that hole, at least not on my '52.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Thanks, Scooter... I will make it disappear as I clean up the unneeded holes in th kickboards.
1952 Chevy 3100
Master cylinder access.
1955 Chevy First Series 3100
1955 Chevy 210 Sport Coupe
Ber 2, Master cylinder access is the larger diameter hole on the left side of the transmission cover opening. His picture is looking up from underneath. He is asking abut the smaller hole in his picture to the right of the transmission cover opening before you get to the battery box cover. My 1951 3100 original cab floor does not have that hole either. smile
~ Dan
1951 Chevy 3 window 3100
O Online: Content
My truck doesn't have that hole, either. It does have that one you closed up in the center, directly above the driveshaft. I have no idea what that one is for.
1950 Chevrolet 3100 (Ol' Roy)
I believe the center hole is a drain given that it is at the lowestpoint of the floor pan depressoin that can easily accumulate water if it enters the cab.
1949/50 3600 Project
Follow in Project Journals
O Online: Content
That makes sense.
I closed up holes within the seat riser area (the drain hole and 1 other hole) because I have a Glide Engineering seat where the seat cushion opens up to yeild a good bit of storage under the seat. I thought that if I might use that storage space, then I should close the holes with welding, rather than a rubber plug.
1952 Chevy 3100
