Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (46 Texaco, Forty9, Guitplayer, 1 invisible), 182 guests, and 2 robots.
Topics128,279
Posts1,058,582
Members48,492
Page 1 of 2 1 2
1947.2 through 1955.1.
Let's start a list of parts not available from the reproduction market. Let's try to keep it to original style parts. Should be a relatively short list.
I'll start.
Frame.
318 synchronizer drum.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
55-59 panel / suburban stock gas tank. On rail type.
3/4 ton and 1 ton brake drums!
52Cark, I think the list may be a lot longer than you hinted at. Especially considering 1 ton and larger trucks. Think brake drums and related brake system components just for starters.
Will have to see how this list goes to see if it can prove to be beneficial or not. headscratch
~ Dan
1951 Chevy 3 window 3100
Most Huck brake parts, particularly wheel cylinders, hardware kits, etc.
Ranco valve for heaters
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I purchased new Huck brake wheel cylinders and shoes from Rock Auto. Jim Carter sells the drums and I think the springs.
1950 Chevrolet 3100 (Ol' Roy)
24601
24601
Carl -- I think your list *is* very short .... But only if you keep it to 3100's. For 3600 and up, the list gets ... significant.
My additions (that I am somewhat certain of)
1-ton PBrake cables
1-Ton rear wire harness (to the taillight) -- All available wire harnesses are for 1/2-tons. Granted, they are identical, except for the harness to the rear (Um, it's longer for the 3600 and even longerer for the 1-ton)
1-ton bumpers and brackets
4400 and up grilles (Yes, Virginia, they're different from the little trucks.)
Spare tire carrier pieces for the earlier and larger AD's
Non torque-tube driveshaft carrier bearings (the big rubber piece) for 3/4 and up.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
2 Offline
The 1 ton park brake cable is reproduced
Jim Carter truck parts:
MEB491
And I vaguely recall the 53 one someplace else unless that’s the one year you can’t get?
all the brake parts except the drums are reproduced for all years of the 1 ton 47-54
The cylinders and pads and all the hardware is pretty much all at just Napa if you don’t want to shop around
I just rebuilt my brakes on both a 53 and a 50 one tons last summer and my drums fortunately seem to be new because the previous owner was a heavy duty mechanic and back in about 1990s he was able to source new drums through his network and I was able to just swing by Napa for new pads and the wheel cylinders and hoses.
Edit: if you are shopping for the backing plates and some of the connecting linkages in the brake dept. then yeah non wearing bits are likely not reproduced and used is your only option for a one ton and up
The filler panel between the front bumper and grille for specifically 1954 gmc is not reproduced
It is unique to that year and has extra clearance on the sides for the new chrome below the headlights
-s
24601
24601
Well that's good to know.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Moderated
Moderated
1954 gmc 100 lower corners of grill
5588
Authorized Pest
Authorized Pest
Hey Mike. That's your 4th approved post. From here on, you have 'Bolter privileges. Be sure to check your PMs. Welcome to the site.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Man this thread is going to get unwieldy pretty soon, with some saying stuff is not reproduced, and others pointing out sources for various items. A consolidated list would sure be nice, but would take some work to glean that out of all the responses.
But in the interest of information, please carry on.
I'll add brake and clutch pedal shaft/bracket. But I guess that would fall into the frame category, even though it's a bolt-on. ohwell
I had '47.2 through '55.1 pickup trucks in mind when I started this thread. I don't mind it straying away from that.
Some responders have brought up some sources for some of the parts thought to be unavailable. That is a big plus!
Professional procrastinator
Neither 47 or 48 GMC front bumpers are reproduced. The front grill is not available either. The correct electric temperature sending unit is NLA. The intermediate shaft for the GMC 1/2T long bed is made from mostly obsolete parts.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Twin Jimmys, I know you have a ton of experience and knowledge on the GMC trucks. Is the link for bumpers provided by Ron above in error when applied to the 1947-48 GMCs? My guess is yes, that those are just generic reproductions that someone figures will work in place of the originals. Yes/No/Maybe So??? headscratch
~ Dan
Were '47/'48 GMC bumpers different from the later ones? Maybe the LMC ones are all the later version but will fit on '47/'48?
I bought rear bumper brackets for my 1-ton pickup from Jim Carter.
Mike Barnes
1950 GMC 1-ton pickup
The link takes you to generic bumpers that will fit both Chevy and GMC. In 47/48 GMC used a heavier duty bumper with rounded edges on the top and bottom. Almost like a reinforcing edge for strength. Chevy was not a flat bumper as it had a crown from top to bottom and certainly a curve left to right. GMC had the same crown and curve but added a lip on the top and bottom. Both the 47 and 48 share the same part number and are identical in every way but one. The 47 bumper had 4 extra holes punched in it at the outermost ends. The holes were plugged with bumper bolts that bolted to nothing. Just for looks I guess. I have attached pics of both types. I have not seen a 47 style bumper on an original 48. Must have been a bean counter that pointed out the savings on parts and labor if they put 4 less bolts on that served no purpose.
Part #2229571 listed as SHIELD - steering gear exhaust pipe. I have a thread going on this part with pictures. Not sure how to link it here but I will try. This appears to be 47 GMC only unless somebody else chimes in. heat shield discussion
Moderated
Moderated
5588
Haunting the SBP since 2001
Just off the top of my head :
No one is reproducing the outer stainless windshield trims for 1954 & 1955.1 Chevy or GMC .
No one is reproducing the 3/4 & 1 ton hubcaps for 1954 & 1955.1 Chevy trucks.
No one is reproducing the inside dash to windshield trim for the 1954 & 1955.1 Chevy or GMC.
No one is reproducing glove box doors for the 1954 & 1955.1 Chevy or GMC .
No one is reproducing the 1947-1955.1 Chevy or GMC One ton step side running boards { 87'' long }.
No one is reproducing the inner door surround windlace securing trims for 1947-1950 Chevy or GMC.
54 3100 rear bumper.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
Good to know! Thanks!
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
Were they new reproduction or used? I have heard that they do acquire hard to find used parts to resell.
The bolt-on crossmember for securing the torque ball mount on pre-'54 trucks.
1/2 ton both left and right rear axle shafts are not available.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
15" 8-lug wheels
Chris
G.O.T. (Good Ol' Truck), 1953 Chevy 3609 AD 3/4 ton with original 216 c.i. engine, 4 speed transmission, stake bed
1956 3100 non-V8 hood emblem
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Front spindles, every model.
Maroon bakelite Korean War era windshield wiper, door handle, and cowl vent knobs.
Moderated
Moderated
I’m not finding any fuel tank replacement for 1947.2 through 1948, 3/4 ton (3600) trucks
3tries
Let's not forget the all elusive 235 main bearings for (I believe) '47 thru '55.1.
S2
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
BTW, watch out for the replacement lug nuts from China. Inferior materials. I've stripped a couple of them trying to tighten down. Don't know if you can get repro American made.
Are they different than for 1/2 ton trucks?
Yes, not at all like 1/2 ton tank. Only used under bed tank for two years. I repaired mine. Found a pair of plyers inside.
1947 3600 Chevy
Did you clean up the pliers? Can you still use them?
How many gallons is that 3600 tank?
Page 1 of 2 1 2
