10 members (Hotrod Lincoln, Gdads51, Paul Mullen, Ponchogl, DavidBraley, Bill Hanlon, Otto Skorzeny, TUTS 59, Shaffer's1950, 1 invisible),
100
Mod | | | Forums66 Topics128,185 Posts1,057,200 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 5 Junior Member | | Junior Member Joined: Jul 2007 Posts: 5 | I just joined the site and I first posted this in another area before I saw this section for big trucks.
Anyways, I need to haul a '53 or close to that year 6500 cab and chassis. I just want to know if it is within the weight I can haul on my car hauler. Some ones title should list "unladen weight"? (I don't have the title on this one)
Thanks. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Cab, & chassis weight of a truck that size will be around 4800-5200lbs. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I moved your post in the General Truck section to here.
I have hauled many of the 6000 series trucks easily with an F-250 PSD and a gooseneck trailer with brakes. The only trouble I had was with one with no engine and tranny and a heavy steel bed. It was too heavy in the rear and I had to slow down. With no bed you should have no trouble. (Assuming your trailer has brakes.) | | | | | Joined: Jul 2007 Posts: 5 Junior Member | | Junior Member Joined: Jul 2007 Posts: 5 | Thanks guys. Cletis: I deleted the other one now.
I've got a '93 (pre power stroke) ford 250 with a tilt car/equipment trailer with dual 5,200s w/brakes. It's bumper pull (well, receiver hitch, I ain't dumb enough to acrually use the bumper) I use a 1,000 weight distributing hitch and I've hauled a small dozer and a farm trakter that weighed about 8,000 before, so this should be fine, I just wanted to make sure.
Thanks again guys. | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I'm just wondering if any one has hauled one with a car dolly that the front wheeles sit on? probably too wide to fit on a car dolly.
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't know about a car dolly, would probably be about the limit weight and safety wise. I have towed one with a tow bar with all 4 wheels on the ground. [img]http://thumb9.webshots.net/t/58/458/3/29/25/2811329250080251109DYqOrz_th.jpg[/img] It worked quite well for the about 3,000 mile trip from WA to NY. However, I would not want to tow a truck that weighed more than my towing (lead) truck. Brakes and weight over the rear wheels of the towing truck are very important things to consider. Grigg | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | My only thinking is that I tow my 26' boat with twin small blocks that weighs 6,000 lbs with my k2500 chevy pickup no problem. The trailer is a duel axel and has no brakes. You do have to plan your stops but it's not bad. I'm going to move my C50 to Maine about a 2.5 hr trip in a vehicle made in the last 20 years. to do some work at my camp there. I don't really trust it that far, and it would be a hell ride on the highway.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it runs and drives and stops, and has had no major problems in the past year or so driving locally then drive it to Maine.
I had driven my 52 1 ton around town and never out of the county for a few years before I took a trip around the country in it, 8,000 miles with only a broken fan and a bad generator bearing. You really don't know till you try do you? If it works around town chances are it will be fine on a trip.
Grigg | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Ya, you're probably right. 8,000 miles! you are a mad man Grigg. I guess I should give it a try.I got to get it running smoother, having a carb problem I believe right now. Idles rough can't find a vacume leak and Ignition aready gone through. Just idles poorly/lean?
| | | | | Joined: May 2007 Posts: 12 New Guy | | New Guy Joined: May 2007 Posts: 12 | Hi, My 48 6400 w/dump grain bed weighed in @9000#. The trailer tips the scales @just shy of 2000#. I towed this combo in 2004 from north central Kansas to Salt Lake with 3/4t Chevy 2wd, 350eng,4sp manual. No problems except miserable fuel economy and 25mph on some of the expressway hills. Dual 7000# axels w/brakes on receiver hitch trailer. Kept load over axels and it was fine. Weights are from truck scales at local dump. | | | | | Joined: May 2005 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 41 | Hey rust master, I can speak from experience concerning the tow dolly. Don't do it! Going straight would be ok, but wait until you get to the first sharp turn. The towed truck and dolly will not try to go straight, it will go straight! Lesson: with a car dolly, the tow vehicle should always out weigh the towed truck. Unless of course you enjoy replacing little old ladies white picket fences. Sorry, I digress.
Terry Wofford '52 GMC 3 1/2 Ton '51 GMC 2 1/2 Ton '53 GMC 1 1/2 Ton '53 Chevy 2Ton "If it ain't broke, well give me the keys and I'll be right back!"
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Grigg is definitely a traveler I think we should nickname him Magellan | | |
