| | | Forums66 Topics128,263 Posts1,058,132 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 1 Moderated | | Moderated Joined: Mar 2019 Posts: 1 | Okay I am new to all of this, but I think my 3800 frame is cut down slightly. I have an opportunity to buy a 3600 frame. Will that work or will I need to go a different direction? Thanks everyone!! | | | | | Joined: May 2015 Posts: 11,254 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,254 | What year is your truck? The Factory Assembly Manual for 47-54 trucks shows the 3800-4100 frame as 221 inches overall length, but the 3600 as 185 inches. Also, the 3600 has a hump over the rear axle, while the bigger frames are flat all the way back. I suppose you could adapt it, but it would be shorter than your 3800. Welcome to Stovebolt You might consider heading over to the Welcome Centre and introducing yourself and your truck. We'd like to see pics of your truck as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The info Kevin has provided says no in my opinion. Also, what does "cut down slightly" mean exactly? Options: 1. Buy a 3800 frame. 2. Live with what you have 3. Fix the one you have 4. Sell  As said, need a bunch of pics of issue.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
