6 members (fonz8261, klhansen, TUTS 59, Hotrod Lincoln, Geo55, Gdads51), 122 guests, and 3 robots.
Topics128,165
Posts1,056,989
Members48,458
1957 3100, 235. Is there a diagram, schematic, laying out which hole, and even which grommet, is used for the cables, wiring and tubing running through the firewall? i.e. speedometer cable, oil pressure tube, vacuum tube for wipers, etc.
Thanks in advance!
1957 3100, 235 with 4 speed floor shift
The Factory Assembly Manual has those diagrams. If you are going for an original build, I can't recommend picking one up strongly enough.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I have an electronic copy of the 1955-59 FAM. Below is fairly readable pic of Section 1, Sheet 39 that provides the Dash and Toe Board layout and routing/mounting diagram. Hope this is helpful. wink
EDIT: The lower left diagram applies to your 3100.
~ Dan
1951 Chevy 3 window 3100
Excellent! Just what I needed!
I will track down a FAM.
Thank you both!
They are $21 at Rockauto.
Part Number: 55TFA
It is well worth the investment. You might also consider a shop manual for the GM repair/maintenance procedures. Some of the instructions are 40-50 years out of date as best practices have changed, but it is a good place to start for questions.
1955-1959 Factory Assembly Manual PDF
