8 members (1955 1 Series, jmoore, Rusty Heaps, WICruiser, NorCal52Suburban, walter74, Gray_Ghost, Goach2),
86
Mod | | | Forums66 Topics128,194 Posts1,057,264 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 51 | Hi all, we have a 1953 3100 and we are replacing all wheel cylinders and brake shoes and the master cylinder. Also replacing lines as required. New master cylinder also. Ran into this problem, when removing wheel cylinder on right rear it had a brake line block installed to the cylinder with a bolt and then the axle brake line connected to it.Went to left rear and different type of wheel cylinder was installed without a brakeline block. Installed the right rear with the brake line block on it. So now I need to find out where to purchase a brake line block for the left side. I would think that one should be installed on the left rear also. One other problem is the old master cylinder had 2 ports; one for the left front line and other is for the remainder of the brake system. New master cylinder only has one port. So it looks that I need a block to attach to master cylinder with two ports. Hope all you fellow stovebolters can point me where I might purchase the needed parts or possibly a work around. Went to three auto parts stores and got 2 blank looks and one after checking his computer said can not find anything. Thanks in advance for help and guaidance. Dave | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | I would strongly recommend picking up a Factory Assembly Manual (FAM) so you can see how it was originally assembled.
That said, are you going for all original? If not, you can get tees, blocks, and couplers at your favorite hotrod shop (Summit/Speedway/etc). | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Also replacing lines as required. Dave, unless you replaced some of the line in the past you really should replace them all. They can look new on the outside, but be rusty on the inside. Brakes are not an area to only do half way...replace it all, steel and rubber! Mike B  | | | | | Joined: Jul 2020 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 51 | You are right Mike about rusty brake lines. I only have a couple more to replace. Yes we are keeping truck close to original so it will not be a hot rod.Thanks for the info Dave | | | | | Joined: Sep 2009 Posts: 6,024 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,024 | Dave, You can get the correct 1/2 ton Brake Line Block your missing under Jim Carter Part# MEE245. You will also need the correct style bolt and washers available from the Filling Station under Part# SA-310. Jim Carter lists a brake block bolt, but the descriptions states for 1936-50, so not sure that it will fit your '53. Others should be along soon to add info about the master cylinder and brake line routing to help resolve that predicament. The topic has been recently discussed, so you may find something helpful using the Search the Site link to find recent discussions.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2020 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 51 | Dan - Thanks for the info. I will order from then both. Dave
