2 members (cmayna, IHPWR), 142 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
AD Addict & Tinkerer
I recently replaced my cab corners and on the inner cab corner there is a hole about 1” that came with a plug from the factory. My truck still had one of these plugs installed but is deteriorated to the point it needs to be replaced. Has anybody found a vendor where these are available? The picture shows the hole.
Phil
Project Journals
Stovebolt Gallery Forum
Phil, Perhaps this 1" hole plug would fill the need? Lots of other offerings that may be suitable depending on what appearance you want. I web searched 1" rubber hole plugs. wink
~ Dan
1951 Chevy 3 window 3100
K Online: Content
Just search for rubber grommets and get an assortment ,may come in handy for some other areas
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Also check Ace Hardware. I've had good luck with them.
Thanks all for your suggestions. It gives me a place to look.
Phil
Project Journals
1 Offline
Lots of 1" body plugs on Ebay.
I just bought a couple of them from Restoration Specialties. Their PN 200724-SCR.
Here's a link.
I bought some from amazon. Here is a link.
I ordered these this morning before I saw the link Kevin posted. There not GM style but they should work.
Last edited by Gdads51; 02/12/2024 2:03 PM. Reason: remove tracking data from link
Phil
Project Journals
