4 members (cmayna, 52Carl, CATMAN, J Lucas), 126 guests, and 2 robots.
Topics128,195
Posts1,057,380
Members48,471
#1536057 02/08/2024 6:26 PM
Greetings
I am wondering if anyone here has installed or put thought into the use of a clutch fan on a AD truck. The truck in question is a '55 1st series. The issue I foresee is space, but I would wonder if this could be overcome, as I reckon a clutch fan would make for a quieter ride. Thanks
A while back, I briefly looked into this very question. I think it could probably done, but I either got distracted or gave up, before I found the right combination of parts.
Moving the radiator forward would make it easier, I wasn’t interested in doing that.
1951 3100
Believe me, the fan noise is the least of your worries when in it comes to driving an AD truck. Wind noise, valve clatter, creaks, squeaks , and rattles will cover up any noise coming from the fan. Stick with the 4 blade factory fan. If you have cooling issues, look elsewhere because the fan ain't the problem.
1950 Chevrolet 3100 (Ol' Roy)
