Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, Peggy M, 55shaker), 30 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
Page 1 of 4 1 2 3 4
1951 Chevrolet 3100
Time to post a few pictures and start the story.
Hauled the 1951 off to my friends body shop last Saturday. Finally got all of the yellow from an '80's paint job gone bad taken off. It was a long tedious process. I had tried chemical strippers of all brands and came to the conclusion that like a lot of things, they aren't what they used to be.
I did a 1971 rs/ z28 Camaro back in the late 80's and chemical strippers worked great. So I ended up doing this truck with 3M surface conditioning pads and an angle grinder. Some paint rolled off like a ribbon with a sticker scraper. Around the window channels I used a dremel tool taking several hours on each side to get every last bit of paint out of the nooks and crannies.
I was very fortunate to find this truck here in the northeast. The guy I purchased it from brought it here in 2009 from Colorado. He had purchased from a gentlemen who had purchased it in 1992 in Southern California and moved to Colorado in 2005.
From 2009 to when I bought the truck last May, it was stored in a climate-control garage along with 10+ '60's vintage Corvettes. Several of which are restored to Bloomington Gold standards.
It ran and drove when I brought it home.
I first started by sorting all the nuts and bolts and pieces and putting it mostly back together. Included in the purchase was a bed full of new parts to aid in the resurrection of this '51. As many of you guys have seen, I had two of everything. I have had to buy very few parts so far.
So from May through August, I rewired the truck, painted the inside, did the gauge. Also installed a drop axle in the front from Sids and Poise Super Slide Springs.
That will be the extent of any major modifications away from original for me. I just like the stance that lowering these truck produces.
I hope to have the cab and chassis back within a few weeks.
Note: Jeff started his story in the DITY Gallery and soon enough, and sure enough, he had enough details on his build, that we invited him to roll over to the Project Journal special lot. wink He has not disappointed, that's for sure. Thanks to you Jeff, many will benefit from this thread and these great images. (And thanks for answering the questions that folks have asked. thumbs_up )
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
Making good progress. Just pulling little dents and going over entire cab. Removed the windshield. All in all in excellent shape there.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Looking good, keep at it!
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Thanks Homer,
Fill primered yesterday. Blocking it off today and laying down epoxy primer. And hopefully color by Friday afternoon or Saturday. Going with the original Seacrest Green with a flat clear.
Jeff
Follow in the DITY
1951 Chevrolet 3100
The day went well today. Finished all the minor imperfections and got the cab and door all under epoxy primer.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Color and flat clear coat went on yesterday and today. Very happy with results. Can't wait to get the rest of it under color.
Stay tuned!
Jeff
Follow in the DITY
1951 Chevrolet 3100
Bond Villain
Bond Villain
Looking great, Jeff!
With a color like that, it looks like it should have a Detroit diesel in it! wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
That would be fun! Seacrest Green is the color. Looks a little different outside. Beautiful day in North Central Pennsylvania. Good day to move the truck home -- 54 degrees for a high. Tomorrow night into Tuesday morning calling for 6-9 inches of snow.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Love that Color!
1950 Chevy 3100
Looking good and goo# progress. I like 6.
Good night in the shop tonight with my 11-year old son Jameson! Two hours and 10 attempts later, the back window is in stalled!
SWEET VICTORY!
Haven't been in the shop much the last two weeks. Life got in the way. Sickness ran rampant throughout or household and or businesses. Hope to get back at it hard this month!
Jeff
Follow in the DITY
1951 Chevrolet 3100
Tonight took a shot at installing the the front windshields.
It was much easier than the back window. Popped right in . Took less than ten minutes. Was also multi tasking today. Painted a bunch of parts. And while in between coats allowing things to dry. Installed the sound deadening strips and insulation under the seat. I normally keep my shop at 60 degrees.l, but bumped it to 70 today to improve drying time. I does make a big difference. Maybe just my imagination.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Authorized Pest
Authorized Pest
P Online: Content
Any tip on getting the front windshield in? First time for me to hear such a task like that was easy. 😮
~ Peggy M
1949 Chevrolet 3804
I soaked the cord that I used in the channel of the seal in very soapy water. A friend of mine who installs glass for a living suggested that little trick. That was the only thing I did differently from the YouTube video that I found on Stovebolt. I taped the seal to the glass to keep in in place. Set it against the pinch weld, centered it up,did the bottom across both sides up around the first corner. My son just kept a little pressure against it and down . Then just worked both sides up and around the top corner. Then you are home free, Across the top! It had been a long time since I had installed a window with rubber seals. The front clip being off certainly made things a little easier as well. It was way easier than he back window. Mistake I think I made doing the back window was get soapy water on the glass and seal rather than just just on the seal and pinch weld. The seal kept rolling off the glass when it was wet and soapy.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Former Workshop Owner
Looking good Jeff. thumbs_up What brand or type of soap did you use? Dish soap, laundry detergent?
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I have seen in some videos that they used a sealant between the rubber and the pinch weld of the truck. Was a sealant used and wouldnt the soapy water affect a good seal?
1954 GMC Series 1
102-24 Series 1/2 Ton Long Bed
248 to a Hydramatic
The shop manual says to use sealant on the windshield, but it does NOT say to use sealant on the rear window.
On the windshield, sealant is applied to the pinch weld (outer side) before installing the windshield/gasket AND AFTER the windshield is in place between pinch weld and gasket and glass and gasket.
I've found that liquid laundry detergent dries like glue. I've used it to hold intercooler boots in position on my diesel that will develop 20 psi of boost, and have not had them slip off. So it should work well on windshield installation as long as it's allowed to dry fully before applying sealant.
Last edited by klhansen; 03/05/2024 7:32 PM. Reason: added tip on liquid laundry detergent
I just used Dawn dish soap and water in a spray bottle. Probably around a 3 to 1 ratio. 3 being the water of coarse. I didn't use any sealant. My friend who works for Safelite Auto glass advised that since the 3M non hardening isn't available anymore to just see what it does first and if need be I can address it then. Says he puts them in a lot without sealant with out issues. Especially if the pinch weld is in good shape. So that's what I did. Time will tell I guess.
Jeff
Follow in the DITY
1951 Chevrolet 3100
I picked up a tube of CRL7708 non-hardening sealant to use for my windshield install. Haven't used it yet, but it's supposed to be a substitute for the 3M stuff that's no longer available.
Yeah I saw that a while back kl. I will see about getting some on hand. Amazon?
Jeff
Follow in the DITY
1951 Chevrolet 3100
Yep, I got mine on Amazon. Just search on the PN.
Got a few more things done today.
Install a new firewall insulation pad and was able to mount the heater box. Also reused the spring clips and use a small hole saw to cut the liner for wiring and the heater. Also got the seals for clutch, brake and throttle rods installed.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Still plugging along! Managed to get seatbelts installed yesterday. Needed to get that done before I tackled roof insulation and headliner. Also finished up the defroster duct and began the installation of the inside windshield trim.
A couple of hours a day here and there really does help thing progress along. One thing I did that has really payed off recently is when I was disassembling the truck, when I took off a part that I was going to reuse, even just nuts and bolts, I cleaned up the item, painted , bagged and tagged and put it on the shelf. Also took the advise from an article here on the Stovebolt about keeping it fun. Keep the task simple and just step back when you need to. Before you know it it will come together. Even if it's just ten minutes of work on some days. Progress is progress no matter how small. This has become a big stress relief tool for me.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Trucks looking good.👍 You have a nice shop.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
Thanks and Thanks. Built the shop 20 years ago. Same old story ,sould have made it bigger. Best thing I did was install radiant heat in the floor. Have a hot water heater doing the work of the boiler. With natural gas. Very efficient and comfortable to work. Kind of a mess right now.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Worked a little on the dash today. Also reinstall the starter pedal mechanism. I need to get at pulling the gas tank so I can install sound deadening and insulation.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Tackled the rear cab mounts today. Had them both out, disassembled, cleaned,reassembled with new bushings, and painted in about an hour. Let them dry over night and will reinstall them tomorrow. Also got the transmission access cover back on with a new seal.
Jeff
Follow in the DITY
1951 Chevrolet 3100
A piece of 2x4 slipped between the cab and the frame was a perfect fit to support the cab when I removed the mounts.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Took some pictures of the area underneath where the cab mounts are located. Super nice under there! Even the plugs are in place. Also managed to get the tank out as well. Tank is really good inside and out. Cab floor also nice. Clean,paint install sound deadening and insulation and put it back in.
Today's automotive engineers should be taking cues from these old truck. A drain with a petcock in the bottom of the tank!What a novel idea! Anyone who ever took a tank out of a car in the last 20 years knows what I talking about .
Jeff
Follow in the DITY
1951 Chevrolet 3100
Beautiful day in NorthCentral PA today. Was able to work with the shop doors open. High of 65 degrees.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Last night was able to get the back of the cab and the area of the the gas tank cleaned and painted. Finished installing the sound deadening strips and got a good start on the floor insulation. All of these items ive been using the last few days were parts that came with my truck when I purchased it. With that said, the spray adhesive that came with the insulation was junk. No telling how long it had been sitting around. So had to run to town and purchase new spray adhesive. So if you purchased your insulation kits years ago and they came with adhesive. Do yourself a favor and buy new adhesive before you start your install because chances are the old cans are bad.
I hate being in the middle of something and not having what I need to finish it!
Jeff
Follow in the DITY
1951 Chevrolet 3100
the sound deadening strips as well had been around god knows how long. It was hit or miss if they would stick or not. Ended up re gluing a good bit of them.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Got a good start on the carpet today. I hate carpet. Still not sure if I'm gonna leave it in. Came with the truck. Had to back track and remove the parking brake mechanism. So had to cut my floor insulation. I should started on left side in stead of right. But since I had gas pedal in and hole for four speed it was just easier to remove brake. I will patch the insulation.
Jeff
Follow in the DITY
1951 Chevrolet 3100
So over the past weekend I made some more progress on installing the carpet. Only to find myself again having to order a few parts that I thought I had in my stash. Before I can finish up the carpet I needed the steel bezel to go around the rubber boot of the parking brake. this will be under the carpet so it needs to be installed before I can reinstall the complete parking brake mechanism. I did take the cut off piece of carpet and fitted it to the area under the seat. I then attached the carpet with spray adhesive to the sound insulation that goes under the seat. I decided to not glue this section of insulation to the floor so it could be easily lifted out it need be. Prior to gluing the two together I took aluminum tape around the edges of the insulation to make it more durable and to stop it from fraying. I also stripped the horn and primed it to get ready for paint. Also took time to strip the paint of the horn and got it primed. That was a job i kept putting off just because of all the nooks and crannies. I came out pretty well i thought.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Can't believe I havent posted since mid March. Life got in the way again. Kids,sports, travel.
I managed to get most of the interior done .
Got the gas tank back in and finalized also.
Sound deadener and insulation in the roof and the front section of the headliner and visors.
My son JT was a great help with the interior roof details. He was able to work without being hunched over. Extra set of hands were great to have when gluing in the insulation.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Also managed to get the engine cleaned up and painted. Was able to get my daughter Marlee in on the act. She hand painted the embossed Chevrolet logo on the valve cover for me.
Pulled the trigger on the short shaft water pump and fan blade from Jim Carter. Had to grind one corner down slightly on the pump to clear the timing cover. Radiator will fit correctly now. Purchased a 38 inch 3/8 belt locally.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Front bumper and brackets can also be checked off the list. Had the upper radiator hose and purchased lower from jim Carters to accommodate the new water pump and also still fit the radiator.
Jeff
Follow in the DITY
1951 Chevrolet 3100
The bracket shown here is what my generator had attaching it to the engine. Not sure what was suppose to be in the big hole but what was there was a couple of big washers pinching it to the generator. The rubber grommet with the bushings is what I used to correct the cobble job. It is grommet used on gas tanks from my Harley Davidson . It fit perfectly and made for a cleaner more reliable install of the generator
Jeff
Follow in the DITY
1951 Chevrolet 3100
AD Addict & Tinkerer
It’s great to have your kids involved. They will also have an attachment to your truck. You’re making memories that will last not only your lifetime but their’s also!
Looking good!
Phil
Project Journals
Stovebolt Gallery Forum
I worry about your fuel pump.
1950 Chevrolet 3100 (Ol' Roy)
Page 1 of 4 1 2 3 4
Moderated by  Phak1
