0 members (),
97
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 57 | Hi, I've searched the forums but I'm still not sure I found the right info.
I have egg-shaped steering balls on the pitman arm and the third arm, basically the two balls that connect to the drag link.
I understand the removal process but I'm having trouble sourcing the ball studs. Most of them I find state "1/2 ton only". I'm not worried about the pitman arm because, according to the parts books, they used the same one from '47-'50. The problem is the third arm - one was used for the 1/2 tons and another part# was used for the 3/4 - 1-1/2 tons.
Has anyone had luck sourcing these ball studs for the 3/4 tons?
Thanks, Shawn
Shawn
1950 3600 Pickup, 1958 Plymouth Belvedere
| | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | Try the Filling Station. Link Note that this listing shows "except 1/2 ton". They have others as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2011 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 57 | Thanks Kevin,
It looks like that item is only for the tie rod ends. I did some checking and I think their SA-156 or SA-156T will work for the drag link balls. The SA-156 would have to be swedged or riveted over after the old balls are drilled out. The SA-156T can be bolted into place after drilling out the old ones. Funny that they made the tie-rod balls replaceable from the factory but not the pitman arm and third arm balls. I'll post back how it turns out.
Shawn
| | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | I know that I replaced the balls for the drag link on both ends on my truck. I'm not sure if they're the same for 3/4 and 1/2 ton, but I was able to press them out and used the "weld-in" balls that I pressed in place and peened over. I used the SA-156 from the Filling Station.
