6 members (UtahYork, 1955 1 Series, IHPWR, Hotrod Lincoln, KEVINSKI, Jman), 116 guests, and 2 robots.
Topics128,101
Posts1,056,524
Members48,448
There are 2 carburetor control cables that are mounted in the dash. Current setup is that the choke cable is far left, just to the right of the headlight switch. The Throttle cable is installed far right, over the right radio knob. Is this the correct placement? And related to that, there are two 1" holes in the firewall, behind the carburetor. Which holes should be used for the 2 aforementioned cables. And, pressing my luck a bit more...I see where the choke cable attaches to the carb, but where, and how, does the throttle cable attach. Thanks in advance!
1957 3100, 235 with 4 speed floor shift
Google up pictures of 1957 Apache dashboards.
Looks like the choke is on the left of the "V" opposite the ignition switch and the throttle is above the left radio knob.
1950 Chevrolet 3100 (Ol' Roy)
Your carburetor should have a bracket that holds the choke and throttle cable. It will look something like this.
Otto, Thanks! Big help! A follow-up question, since I am very new to the forum. My carb does not have the linkage/hardware of the throttle cable. I would assume I should find a source for a used, salvage type carb? Where would I look? Thanks again!
Yes. They are not easy to find used, I'm told. I think one of the suppliers like Jim Carter or The Filling Station sells them for a pretty penny.
Is your carburetor a Carter YF or is it a Rochester?
Which carburetor do you have?
Rochester or Carter, and model if you know it. Sometimes a tag on it.
Is the manual choke hooked up?
From there we can determine which mount you might need.
Todd
1950 Chevy 3100
I believe it is a Rochester B. Couldn't find a tag. The manual choke is there and works. There appears to be a threaded hole, #10?, on the rear of the carb in the coke bracketry area. The casting number is on the base of the carb. I can try to decipher it if that help.
Thanks!
A picture or two is worth a thousand words...
Please post picture of your carburetor and area where you now have a choke cable hooked up.
Here are a few close ups. Might be similar to your final set up.
Todd
1950 Chevy 3100
Hey Todd, thanks for the pics. They really helped and made it clear that the cable housing clamp is actually still there. But what is missing, or that I need, is just the cable stop that you show at the pedal linkage. Know where I can get one. Lawn mower repair shop? I have done vintage British restorations for years. The Detroit stuff is quite foreign to me. Thanks for your patience!
Yes, they should have them. Any local Auto parts should also carry them!
1950 Chevy 3100
Bicycle repair shops have them on hand, too. They're used for brake and shift cables.
Otto, Bingo!! I couldn't think who carries a ton of them in stock.. Bike Shops!! Although the closest bike shop to me is at least an hour and a half drive...lol. plenty of FLAPS a lot closer..
1950 Chevy 3100
H Online: Content
There's always Ebay- - - -shipping costs would be less than gas to go to the bike shop!
www.ebay.com/itm/122213440774?
Jerry,
I agree with you.. Minus ordering it from France.. haaa
Did you see where it ships from...
Luckily I have a few already.
Todd
1950 Chevy 3100
Moderated by  ndkid275, Phak1
