| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Spanky found this one next door, is there anything special that i should look for.. holmes | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | What year F**d is under that? I know it's not a Bolt, but, hey, an old truck is an old truck, right? Especially a big one. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | it looks like a 58', 58'-60' are very similar. 57' has same sheetmetal but only 1 headlight, 58'-60' has 2. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | That's a Holmes Heavy Duty W35. Should be a Holmes ID Plate located on the passenger side mast upright. Get me the serial number, from this plate, & I can give you the date of manufacture. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Thanks spanky will look for it and post it here. don't know for sure what i might use it for but would sure be handy to move a few things around. any thing i should look for in the operation of it? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Spanky..would this W35 be a predosessor of the 500 or perhaps 600 series? Sure looks like one. I used to sell Century wreckers back in the 80's for a while and we traded for a ton of Holmes iron. A boatload of 440's for sure. Then it went wheellift and rollbacks. Just curious. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The Holmes W35, & W45 Heavy Duty Wreckers, were replaced by the Holmes Heavy Duty 650, & 850 Wrecker units. The W35's, & W45's are much Heavier units, than the Holmes 500, & 600 units. The last W35, was manufactured in June, of 1952, & the last W45, was manufactured in March of 1954. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Hi 55,, it sits next door to me.. he was not home last night so could not get any numbers will try again after work, don't like wondering around when nobody is home.. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Spanky.. the tag is in real bad shape, from what we could make out it has TENNE HOLMES W35 00443 hard to see don't know if thats enough numbers | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Thanks will go back over and take another look, but like i said the tag is in bad shape, will take a pencil over and see if i can trace it out. thanks again for the help | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | went back and looked at the ID plate, could not make out any of the numbers. so its a guess to what year it is. thanks for the help, still discussing price | | |
