| | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | This is for a positive ground 6v system. Using a Signal Stat 900 DOTQQC76. I want to install a 15a fuse. What would have been the positive wire going into the unit now becomes the negative wire. Is this where the fuse is to be used? The unit does work as a positive ground. I used a 535 flasher, but it flashes as fast as a strobe light. What other flasher could I use?
Rick G
1939 Chevrolet Stake Truck
| | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | A fuse should always go on the wire coming from the non-grounded terminal of the battery. No clue on a proper flasher.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,522 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,522 | Most 535 flashers (6 volt, positive ground) are rated for a max of four 32 candle power lamps. This one is rated for six 32 cp lamps. Should slow the flashing down some, but I don't know if it would be enough.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Update -
Finished installing the turn signal lights, turn signal and wiring. Still worked like a strobe light. Going thru my parts cabinet I found a 32cp 535 flasher new in a sealed container. Exchanged it with the old 535 flasher and lo and behold the lights flash correctly.
Thank you folks
Rick G.
