2 members (Snowman51, Steelonsteel), 105 guests, and 2 robots.
Topics128,118
Posts1,056,646
Members48,450
Socket Breaker
Socket Breaker
1965 Chevrolet C10
1992 Chevy truck engine, 350/5.7L(v8)
I run the engine, can not see any spewing coolant, no leaks.
I park it. Check it the next day or the one after... suddenly there is coolant on top of the intake manifold, around the thermostat housing/water neck.
So, my first thought is loose hose clamp or not adjusted right on the water neck. Checked that. Gasket for the thermostat housing was replaced in November 2023... maybe it isn't snug enough?
This is making me cuckoo. Anything else I can check?
It only leaks after it sits, never while it is running... or at least not while I am looking at it while it is running.
Thanks.
-Woog
Do you have access to a cooling system pressure tester? I'd suggest pumping the system up to within a pound or two below the pressure rating of the radiator cap (probably 13-14 pounds) with the engine warmed up to operating temp and then shut off, and look for seep leaks as it cools down. I've cured small leaks like that by draw-filing the gasket surface of the thermostat housing on occasion. It might be warped slightly so the gasket isn't sealing equally across the whole surface.
7
7 Offline
I agree with HRL, the thermostat housing is a soft alloy, they deform kinda' easy with heat, age, torque. Remove the housing and file the surface flat. If it is an aftermarket housing with an O-ring, I had poor luck with that style. Make sure the bolts are not too long, are they bottoming before the housing is snug? Also, look at the heater hose connection if there is one in the intake manifold, should be close to the t-stat.
Put your finger there and wet find the wet spot. Either at the hose or the housing.
My housing with the O ring leaked at the base. It was hard to get it fixed after the engine sat.
I used sealant
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I had a chrome plated T-stat housing on my V8 sbc corrode and leak from under the chrome. I was amazed how the inside was all eaten up...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Socket Breaker
Socket Breaker
Thanks for the replies folks.
-Woog
