| | | Forums66 Topics128,051 Posts1,055,735 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2021 Posts: 9 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 9 | Have the original door window trim from a 51, attempting to install in a 52 Dynacorn reproduction cab. The screw holds do not line up with anything.. My question is are there some type of clip that I am missing, or do I weld a tab onto the door frame. Thanks in advance . | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Our you referring to the outer trim or inside trim on the door . | | | | | Joined: Oct 2021 Posts: 6,757 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,757 | What does Dynacorn say? I'd call them first.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Dec 2021 Posts: 9 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 9 | | | | | | Joined: May 2015 Posts: 11,036 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,036 | I think in your case, I'd carefully drill holes in the door to match the inside trim holes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | No clips, no tabs. The screws avoid what they need to avoid and screw in to the hollow areas of the door. | | |
