7 members (ShopRag, GrandpasJimmy, klhansen, greenie-reddy, SmalltownTRKGuy, 2 invisible), 153 guests, and 1 robot.
Topics128,283
Posts1,058,263
Members48,483
#1533986 01/24/2024 2:47 AM
Have the original door window trim from a 51, attempting to install in a 52 Dynacorn reproduction cab. The screw holds do not line up with anything.. My question is are there some type of clip that I am missing, or do I weld a tab onto the door frame.
Thanks in advance
Our you referring to the outer trim or inside trim on the door .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
What does Dynacorn say? I'd call them first.
1950 Chevrolet 3100 (Ol' Roy)
It's the inside.
I think in your case, I'd carefully drill holes in the door to match the inside trim holes.
No clips, no tabs. The screws avoid what they need to avoid and screw in to the hollow areas of the door.
