0 members (),
54
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2022 Posts: 70 'Bolter | | 'Bolter Joined: May 2022 Posts: 70 | There is some thread damage on a spindle hole for the Zerk fitting. The Zerk fitting is the larger 1/8" NPT (I believe that's correct) which uses a 7/16" hex wrench or socket. I'd like to touch up the spindle threads with a tap. Not sure which tap size to order from McMaster-Carr. What is the correct tap for these this Zerk fitting?
Thanks, -Mike
1955 Chevy 2nd Series 3100 Stepside, 235cid
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | A standard 1/8 npt thread tap should get you what you are looking for. You should be able to get one at a local hardware store. It may be necessary to grind off some of the thread lead to get the depth required as these are probably tapped npt thread short
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: May 2022 Posts: 70 'Bolter | | 'Bolter Joined: May 2022 Posts: 70 | And I have it correct that the Zerks on the spindles are the 1/8 NPT, not 1/4 - 28 taper? Looking again at McMaster-Carr I now see the "1/8 NPT 27 TPI" under the Pipe and Conduit section. Tap diameter is 0.332 which seems correct. They don't carry a bottoming chamfer so yea, I might have to grind off some of the lead. Wow, $35 per tap! Hopefully, available at local HW store.
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Yes, everything has gone up! Let us know how it turns out.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: May 2015 Posts: 11,037 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,037 | Wow! Home Depot lists them for a bit over $6. $35 is crazy expensive. There aren't Taper, Plug or Bottoming taps for pipe taps, just for straight thread taps, so you'll need to grind the end off if it doesn't clean up without doing that.
[on edit] Rocky's Ace Hardware in Concord has them for $9.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | It appears no one here has ever heard of short projection pipe taps for shallow holes https://www.mcmaster.com/products/short-projection-taps/If grinding a pipe tap bear in mind to maintain clearance angles similar to sharpening a twist drill to prevent breaking off teeth in your part.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2015 Posts: 11,037 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,037 | Curt, You're right, I had never run across those short projection pipe taps. But for what Mike is trying to do (freshening up existing pipe threads), there's no need for lead-in chamfers on the tap. The taper of the tap and the existing hole will let it start just fine. And if he bottoms out in the hole grinding off some of the tip will work as well, with no need to worry about chamfering. But that tap won't work for threading new holes. The $6-9 taps I found would be better than $35 in my book.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I have made my own "plug" and "bottom" taps for years by modifying regular taper taps, which are usually a lot less expensive than the 3-tap "sets" that are available. "Thread chasers" can also be made from taps too dull to make clean threads in unthreaded holes by using a sanding disc to blunt the tops of the threads. That prevents cutting a thread oversize when it's necessary to clean up rusty or damaged threads. A rechargeable, variable speed drill motor makes short work of thread chasing. Jerry
| | | | | Joined: May 2022 Posts: 70 'Bolter | | 'Bolter Joined: May 2022 Posts: 70 | I found the correct tap at a local hardware store for $8.95. Much better price!! Was able to clean out the spindle threads.
-Mike
