Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (NJC, 55shaker, cmayna, baldeagle, Mr Bailey, 50Chevy3100, TexasA&M48Truck, 2 invisible), 44 guests, and 0 robots.
Topics128,005
Posts1,055,263
Members48,418
#1533678 01/22/2024 2:02 AM
I'm trying to find out how to decipher our GMC engine casting numbers.
All I can find is Chevrolet.
Our # a228396354
Help?
1951 GMC 100
First attempt on a restoration
That is not a casting number. It is the engine serial number stamped on the pad just to the rear of where the distributor goes into the block.
228 is the engine size in cubic inches. All of the smaller GMC trucks used 228 engines from 1939 through 1953. The following digits are a sequential number of 228 engines starting in 1939. The "A" at the beginning means the engine left the factory with slightly oversized pistons and undersized main and rod bearings. The machining process wasn't as accurate back then.
Here is the magic decoder ring for that leading letter.
The block's casting number is on the other side of the block, along with the casting date.
I'll inform my son. He's the one that thought it was the casting #.
Thank you.😁
1951 GMC 100
As always, you guys are great!
1951 GMC 100
Here is a guide to GMC casting numbers.
