2 members (52Carl, Gdads51), 37 guests, and 3 robots.
Topics128,180
Posts1,057,161
Members48,464
Hello, does anyone know of headliners for the 47-53 Chevy Panel trucks...? Has anyone here done their Panel?
Last edited by Toms49Panel; 01/18/2024 8:25 PM. Reason: added more info to the title
Check with MNSmith (Moderator) on here. I think he has made them from abs sheets.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Have you looked at page 8 of this?
Authorized Pest
Authorized Pest
HERE IS a Tech Tip on "ABS headliner Installation" in the Interior Tech Tip Forum. Will it help? It is also still in the "Back Room" as a web page.
HERE IS one from the Legacy TTs: "Cardboard Headliner Installation -- Patience plus Persistence = a nicely installed headliner!"
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Thanks everyone, you're the best!
I only made one and that was for my Suburban. I had a few people interested in me making some for them, but I wasn't interested in that. I didn't want to remove mine to make patterns. Plus, they were interested in only profiting from my work without doing any work of their own. They eventually figured it out and started making kits. I think the end result is what you see linked above. Someone already making ABS panels added it to their list of kits. But, I still haven't seen anyone make side panels or panels for the rear doors. My job starts near the bottom of this page: http://www.bunchobikes.com/1952suburban4a.htm
Great info MNS ! Looks great !!
Sir Searchalot
Sir Searchalot
I have a tech tip for headliner. Task Force Panel and Suburbans. May be useful for AD and others. Click
This is a very old Tech tip. Was lost, but now found. Prices are maybe 8-10 years old.
I went to a local upholstery shop and told them the design I wanted and they did a wonderful job of it.BTW it is vinal and isolated above with the Chevy logo imposed on it.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Nice!
There are kits available from the regular vendors for the original style cardboard, but only have the first 2 pieces. I got a headliner from Classic Parts. The first piece was short on the edges and left a gap over the door opening. Here is a picture without the trim in place, it looks less bad with the trim, but it is still bad. My truck is a ’47 so may be different from later years. The headliner in the cargo area looks like canvas that is painted grey. It was installed as one piece between the ribs and the roof, so I don’t know how it could be replaced without removing the roof, or the ribs. The original cargo area walls had cardboard that was grey and had a rhino texture. I used Grey Tolex glued to Cowl Board.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
V
VEW Offline
V Offline
I’m a cheap a$$ and used that silver stuff in my Grumman. But I’m not going for points and it works for me.
You guys do nice work!
~ Victor
1957 3100 - moved on
