2 members (baldeagle, Hotrod Lincoln), 50 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#1531477 01/03/2024 4:34 AM
When my daughter used my truck for family Christmas pictures the photographer took a picture of my engine along with a few other truck pictures to show her husband. This is a picture that she took. I thought it was quite good and I would share it.
1947 3600 Chevy
Very shiny!
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Really nice. I look at a lot of classic vehicle photos and most must spend all the money on the body of the vehicle and not any on the appearance of the engine compartment. It makes you think about what else was neglected in the restoration.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Nicely done!
Mike
Nice where did you get the air cleaners? i have i believe the same carburetors (3) i bought them from Stove Bolt but i have no air cleaners.
Jay D.
Summit Racing sells air cleaners like that.
1950 Chevrolet 3100 (Ol' Roy)
jay d #1532744 01/13/2024 2:02 AM
Jay D.
Here is a similar one from Speedway: Link
H Online: Content
It might be a good idea to research the airflow those air cleaners are rated for. It wouldn't surprise me to learn that they're a bit under capacity for a 235 engine, especially at highway cruise speed. I run one approximately that size on my Harley, and it's OK for an 80 cubic inch engine. It might be wise to consider using filters that are a little taller, and/or larger diameter on the engine in the photo. Just a suggestion.
My carb set up came from Tom Langdon. They are 6” diameter and have the same circumference as one 12’ air filter. They are taller than most paper filters that are bigger in diameter. I think the 4” would be small from speedway.
1947 3600 Chevy
Speedway sells them in 4"/6"/10"/12" diameters. I couldn't tell what size you had and just offered that one as an example.
The bottom plate was made to fit the Weber carbs perfectly. I would call him and see if they are still available if you need this air cleaner. Tom is semi retired and 12 bolt .com took over some of his business.
1947 3600 Chevy
