10 ...................... is 1/2 ton ...1 .................... is short wheelbase .....22 ................. is 228 cubic inch engine (the only one available) ........ P ............... is manufactured at the Pontiac Michigan plant ........... 24831 ...... is the 23831st truck built. The first one was 1001
Additional info can be found here along with the year decode based on the serial number 24831.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
According to the info I have (from an LMC catalog), the plant code letter (P) wasn't used until 52-55 model years. Also Bill's link says the same thing.
But the serial of 24831 is lower than the 1952 Pontiac plant range of 28736-49333 for 1952 production. So that says it's a 1951, but the color of your gauge cluster says 1952 or later according to Jim Carter (but that could be wrong).
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Thank you for all the information. Since we're not the original owners, I have no idea what was changed over the years. I don't know much of anything about the old trucks, just that I like them. 😂😂😂 I wanted to find an old car like one of the ones my dad had, but hubby wanted a truck more. If we do another old vehicle, it will be my choice. He'll have to deal with it. 🤣🤣🤣
