2 members (Brian Moore, J Lucas), 67 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#1529 10/19/2003 1:49 AM
I would like to hear a few experienced opinions on using the 235 as an all around daily driver (and not swap it out with a v8). It will be pulling a '52 1/2 ton panel truck. I will occationally need to pull a 4500 lb boat up a boat ramp and home about a mile away, so I would install a type 3 hitch to the frame.
Also, I just figured out that my new toy has folding "bucket seats" up front (one covered in leather in excellent condition; the other in fabric that is totally shot). Were these seats typical for this vehicle? It also has an original wooden bed (with the steel runners like the pu)in back that I've been told is rather rare. Is this so?
#1530 10/19/2003 2:50 AM
If you have the granny low 4 speed that should be no problem. I always towed my 4500LB boat with my Fjord inline 300.
I think the bed is stock in those, but your truck is pretty rare. I would keep the engine if it's running good.
54 3100 with 235
62 flatbed dump C60 with 261
#1531 10/19/2003 3:09 AM
Granny gear with your 4-speed will pull nearly anything the truck can hook to and have traction
