1 members (Nick in Manitou),
70
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 6 Member | | Member Joined: Oct 2003 Posts: 6 | I would like to hear a few experienced opinions on using the 235 as an all around daily driver (and not swap it out with a v8). It will be pulling a '52 1/2 ton panel truck. I will occationally need to pull a 4500 lb boat up a boat ramp and home about a mile away, so I would install a type 3 hitch to the frame.
Also, I just figured out that my new toy has folding "bucket seats" up front (one covered in leather in excellent condition; the other in fabric that is totally shot). Were these seats typical for this vehicle? It also has an original wooden bed (with the steel runners like the pu)in back that I've been told is rather rare. Is this so? | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If you have the granny low 4 speed that should be no problem. I always towed my 4500LB boat with my Fjord inline 300. I think the bed is stock in those, but your truck is pretty rare. I would keep the engine if it's running good.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Granny gear with your 4-speed will pull nearly anything the truck can hook to and have traction
