8 members (BarryP, NorCal52Suburban, Hanks custodian, Bill Hanlon, rfs56trk, Donf, Frank50, Gazz),
122
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Virus from I'm on tablet Now. What can I do about the laptop.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The whole thing is suspect because I am being asked to renew macafee overlaying the warning. It is overlaying this page. How can I get around this? I still believe it was an advertising gimmick. But I could not leave it alone so I started clicking anytime something popped up and now it is gone.
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | If this MacAfee scam appears again, press Ctrl, Alt and then Delete keys. You'll see a choice for things. Select "Task Manager" and close whatever browser you are using. Then when you open your browser again it will ask if you want to restore it to match what it was when you closed it. Your answer should be no. Then you should be all right. If you stop using any browser other than Duck Duck Go, you probably won't have as many of these irritations. Merry Christmas!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I do use DUCKDUCKGO. I don't know exactly what I did but your instruction sounds familiar. Thanks. The thing that confused me was that it was PayPal I could not get rid of and when I finally did things were okay unless it is hiding somewhere.
