| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | Couple of questions
Can anyone help tell me what my motor numbers mean! the numbers are 0322557f54s
question#2
I cannot find the oil filter on this 54. Is it possible it doesn't have one i have looked everywhere top, sides, bottom i just dont see it
I found the spot to find the truck vin but not the engine
thanks guys | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Try your numbers here: http://www.inliners.org/ And if you can't see the oil filter it doesn't have one. I felt the same way trying to find the filter on the fire truck's 261 when there wasn't one. I thought all motors had an oil filter... Welcome to the Stovebolt as you (and we all) can learn alot here. | | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | Thanks virginia
I thought i was going crazy i still think i am haha.
What oil do you use i was thinking 30weight non detergent? | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I use Quaker State 10W30. I have not changed it since the rebuild. The rig only has 20 miles in on it in the last year. I'll change it once I get it back on the road at about 1000 miles.
Again...Welcome! | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | oil filters like heaters were optional. all the oil filters I've seen were mounted on the left (drivers) side of the engine, remote canister units | | |
