7 members (MickeyP, jmoore, GMCJammer51, TPR57C, Eisenholtz, 55shaker, 1 invisible), 107 guests, and 1 robot.
Topics128,115
Posts1,056,627
Members48,450
#153011 05/31/2007 9:57 AM
After I rebuilt the 350 in my '62 one ton,I ran it for abouty a thousand miles on regular oil,then changed over to synthetic. I drove on that for about 4 months and it didn't use even a half quart. then I drove to Reno (about 300 miles) and in that distance it used 4-1/2 quarts! Any ideas why if didn't use oil for local driving and driving less than 50 miles each way on the freeway,but when I drove a little more distance my truck started gulping the expensive oil?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#153012 05/31/2007 3:13 PM
speed 6351,
I guess my thought would be it either leaked it or burned it. Have you given it a once over for leaks or did you see any smoke out the exhaust on your way to Reno. I don't think the problem can be pinned on the switch from regular to synthetic. A compression check might find a compromised cylinder...but that's a lot of oil to burn. I would think more along the lines of a leak.
Stuart
#153013 05/31/2007 4:24 PM
Maybe the extended period at operating temperature allowed a leak to open up, that the shorter distances didn't allow for. I wouldn't be surprised if it opened up several leaks that the old conventional oil couldn't fit/leak through.
#153014 05/31/2007 6:03 PM
Check your positive crankcase vent valve.
#153015 06/02/2007 7:25 AM
Pull your spark plugs and see if its burning it. If there is a build up on one side of the plug its coming through the valve guide, if its all over its coming passed the rings.
#153016 06/02/2007 12:13 PM
if you have a leak of that much in 300 miles the under side will be oil soaked and dripping..as far as burning 4 qts in 300 miles you should see smoke..check pcv and plugs look at tail pipe,,maybe you broke something inside..if you cannot find problem go back to a breakin oil and run the snot out of it for another 1000...doc
